2018 Contributors:
C4 Bellhousing / Starter ?
old28racer
Post #1 by old28racer » Wed Dec 20, 2017 12:10 am
I am going to mount a 1971 - 80 C4 pan fill bellhousing to my 300 motor. It will have a 164 tooth flexplate. The starter pattern is two bolt Does this setup take a Long or Short nose starter? Is the long nose for automatic & short nose for manual?
Bad Day Racing Is Better Than A Day In The Stands :mrgreen:
wallen7
Re: C4 Bellhousing / Starter ?
Post #2 by wallen7 » Wed Dec 20, 2017 9:09 am
Yes the starter nose is about 3/8 longer. Just get one for automatic transmission they are all the longer nose.
old28racer
Post #3 by old28racer » Wed Dec 20, 2017 1:11 pm
wallen7 -- thanks, I thought that I had it correct, just wanted to make sure.
Also will a 164 tooth flexplate for a sbf 289 motor bolt on to the 300 crankshaft and is it the same bolt pattern?
Do you have to install a block spacer between flexplate & block?
old28racer
Post #4 by old28racer » Wed Dec 20, 2017 1:14 pm
Ment to add that I know the flexplate must be -0- balance.
wallen7
Post #5 by wallen7 » Wed Dec 20, 2017 1:33 pm
Yes it is the same bolt pattern, you will have to rebalance after removing weight. I have seen them installed without the plate , but I would not advise that.
old28racer
Post #6 by old28racer » Wed Dec 20, 2017 10:37 pm
wallen7 --- I will install the correct block plate. I have an old race buddy that owns a transmission shop and should be able to set me up with a neutral 164 flexplate and block plate to go with a 71-80 C4 pan fill bellhousing. Thanks for the help.
Users browsing this forum: No registered users and 26 guests
