2018 Contributors:
2018 Contributors:
Changing 92 f150 to duraspark ignition
- New Member
I just dropped a 81 300 in my truck that has only 7000 miles on it. I am keeping it carbureted and wanting to put duraspark ignition on it. The only problem ive encountered is findin the correct wire from the 92 harness to hook to the blue grommet duraspark module. Any suggestions. Ive got a coil that doesnt need a resistor. Another question is can i wire into the run and start circuits on the plug from previous ignition module,if so do i still need to run a wire to the starter relay? I also have the starter relay with s and i posts. Will the original harness still work with the oil sending unit and temp.? Of course i know that id have to delete some of the harness because the 92 had 2 temp and 3 oil units i think.
Re: Changing 92 f150 to duraspark ignition
To get started:
Does the starter relay have both the "S" and "I" terminals?
Do you have a Ballast Resistor?
Once you have those two items you can wire the system as follows. See diagram on page two
http://www.painlessperformance.com/Manuals/30812.pdf
The wire shown from the ignition switch to the ballast resistor will be the red/light green wire that went to the former ignition control module and ignition coil.
Double check this connection with a volt meter or 12 volt light. It should only be on when the ignition switch is in the run position.
Users browsing this forum: No registered users and 12 guests
