Advancing the cam
djfalcon10
Advancing the cam
Post #1 by djfalcon10 » Sat Feb 10, 2018 11:34 am
Got my new cam and here is the specs
.567 lift
306 dur
110 lobe center
107 centerline.
Now the company told me to adavance it 3 degrees now i got a cloyes gear set. That has 4 degree adv and retard. But no 3 degree. Now will it hurt my cam and if i adavance it at 4 degrees to get 111. or is there a special key way that will make three degrees. Thank for you help.
pmuller9
Re: Advancing the cam
Post #2 by pmuller9 » Sat Feb 10, 2018 12:01 pm
The lobe separation angle is 110*
The intake lobe center needs to be set at 107* ATDC
You will need to use the .050" duration opening and closing points to degree the cam to the correct posisiton.
Those points should be on the cam card.
It is OK is the cam is off 1 degree but chances are the cam will not have the correct offset and will not be exact anyway.
You will find out once you use your degree wheel to do the cam timing.
Can you post a picture of the cam card?
djfalcon10
Post #3 by djfalcon10 » Sat Feb 10, 2018 12:04 pm
Ok. Now i understand what you are trying to tell me. Just need to make sure it at 107. Thank for your help
pmuller9
Post #4 by pmuller9 » Sat Feb 10, 2018 12:07 pm
what is the .050" duration?
djfalcon10
Post #5 by djfalcon10 » Sat Feb 10, 2018 1:26 pm
Try to download the cam spec. Wont let me do it. Here what my cam card saids
Intake =open/close 25@.050/59@.050
Exhaust=open/close 65@.050/19@.050
Cl at 107 and 113@.050
pmuller9
Post #6 by pmuller9 » Sat Feb 10, 2018 2:13 pm
djfalcon10 wrote:Intake =open/close 25@.050/59@.050
The .050" duration is 264 degrees by those numbers
With a dial indicator on the #1 intake lifter and the crank rotating clockwise only, the reading or lifter lift needs to be .050" at 25 degree BTDC and return to .050" at 59 degrees ABDC.
This will put the half way point at 107* ATDC.
The exhaust lifter will be .050" at 65 degrees BBDC and .050" at 19 degrees ATDC if the cam's LSA is correct at 110*.
Remember that all readings must be taken with the crank being turned clockwise because the cam gear set tooth clearance will give you error if the crank is turned counterclockwise.
Pardon me if you already know all of this but it might benefit someone else reading this thread.
If you can get the cam timing close with the Cloyes gears and still want to have it spot on, then it can be done with a modified offset key on the cam gear.
What size degree wheel do you have?
pmuller9
Post #7 by pmuller9 » Fri Feb 23, 2018 11:03 pm
I'm interested in how the cam installation turned out and also how the engine is performing under boost?
Any Updates?
djfalcon10
Post #8 by djfalcon10 » Sun Feb 25, 2018 11:11 pm
Have not got the motor togetter. Going to take the rods, pistons,crank,flywheel and harmonic balancer . to get them balance. It will be awhile before i get it running. But i will let you know.when i get it running
Stonebreaker
Post #9 by Stonebreaker » Thu Mar 01, 2018 3:48 pm
djfalcon10 wrote:Got my new cam and here is the specs
.567 lift
306 dur
110 lobe center
107 centerline.
So the Cloyes gearset only advances in 4 degree increments? Got a link to the set you bought?
pmuller9
Post #10 by pmuller9 » Thu Mar 01, 2018 10:09 pm
Stonebreaker wrote:So the Cloyes gearset only advances in 4 degree increments? Got a link to the set you bought?
Yes, it will advance or retard 4 degrees using 3 keyways on the crank gear.
There was difficulty getting the Cloyes 8-1014 gear set and some members reported that it was no longer available.
Summit shows a 3/19/2018 shipping date and Jegs site says to call.
https://www.summitracing.com/parts/clo-8-1014
The alternative is to use the Mr Gasket 987G offset key on the cam gear for a +/- 4 degree change.
Users browsing this forum: xctasy and 15 guests
