Offenhauser 3 2 barrel
Angelking
Post #1 by Angelking » Tue Feb 27, 2018 6:17 pm
Wondering if anyone has ever used one of these and if it will fit on the 300.....
[image]Image/image]
Re: Offenhauser 3 2 barrel
Post #2 by bubba22349 » Tue Feb 27, 2018 6:27 pm
That manifold is made to fit the small Ford Six'es (144, 170, 200, or 250's) it won't fit the Ford 240 or 300 big six'es. Good luck :thumbup: :nod:
Angelking
Post #3 by Angelking » Tue Feb 27, 2018 6:32 pm
Thank you!
SM
THE FRENCHTOWN FLYER
Post #4 by THE FRENCHTOWN FLYER » Wed Feb 28, 2018 4:12 pm
If you want something similar you can make a 3 x 1 intake from three stock intakes, using the two center runners from each intake. Go to http://www.inliners.org and look under tech tips for a photo essay.
Angelking
Post #5 by Angelking » Wed Feb 28, 2018 7:15 pm
THE FRENCHTOWN FLYER wrote:If you want something similar you can make a 3 x 1 intake from three stock intakes, using the two center runners from each intake. Go to http://www.inliners.org and look under tech tips for a photo essay.
Awesome, thank you very much..... will check it out...
SM
Shorty
Post #6 by Shorty » Wed Feb 28, 2018 7:17 pm
I have seen this before in another thread and would love to make a setup like this some day. This will clear the efi exhaust manifolds? What does the throttle linkage look like? Any tips to assist in set up? (idle, choke, synchronizing....) Does the plumbing for coolant on the underside make this something that could be run in cool or cold climates?
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
Post #7 by THE FRENCHTOWN FLYER » Thu Mar 01, 2018 9:32 am
I haven't tried it with EFI exhausts - I assume it would work.
I use an intermediate shaft that has three bell cranks to open all three carbs simultaneously. It can be activated by the stock cable with a bracket rework.
Find three intakes with the same carb stud spacing. There are two - 2 11/16 or 2 15/16. Or file carb bases to fit.
A special extended manifold lug clamp will be needed for the front carb as not all mounting lugs have identical locations. Painted orange in the pics.
One center choke should be sufficient.
You could plumb all three heat boxes for coolant heating if desired. Or not.
Shorty
Post #8 by Shorty » Sat Apr 25, 2020 12:59 pm
I finally got the three intakes to cut up and have started this. I tried to look up the photo essay on inliners but it seems they have changed or up graded their site and I can't seem to find it. I have a bare head I am using to make sure things line up and i have added material to the lugs so they line up with the clamping bolts. With a tig and some good filler these intake weld pretty nice once they are cleaned up. I was wondering if it would be ok to index/clock the carbs 90' to make the plumbing and throttle linkage a bit easier?
Would something like this be worth putting in as an intake option in the list of stickies?
jgregg13
Post #9 by jgregg13 » Sat Apr 25, 2020 3:25 pm
I found the above referenced article by FTF on the triple carb intake. It's on the Inliners site, but in a really obscure location. Go to their forum and Ford then there are "Tech Tips" on the LH side.
Ford 300 3x1 intake fabrication
Post #10 by THE FRENCHTOWN FLYER » Sat Apr 25, 2020 4:23 pm
Shorty wrote:I finally got the three intakes to cut up and have started this... I was wondering if it would be ok to index/clock the carbs 90' to make the plumbing and throttle linkage a bit easier?
You could but it may introduce unforeseen consequences like cornering issues. There are three double bolt bosses left on the valve cover side of the runners which are a perfect place to mount a shaft for bell cranks to pull the throttles using short links with ball ends.
Shorty wrote:Would something like this be worth putting in as an intake option in the list of stickies?
I would think so but I'm a little biased.
pmuller9
Post #11 by pmuller9 » Sat Apr 25, 2020 5:06 pm
Done
Users browsing this forum: Google [Bot] and 28 guests
