2018 Contributors:
Our three new heads and when to use them
Wesman07
Post #1 by Wesman07 » Thu Mar 29, 2018 12:34 pm
So I’d like to start a sub discussion about our cylinder head options. Particularly curious about which head would be best for a certain type of build? And which situation would one head be better than the other?
In-lines we trust
Re: Our three new heads and when to use them
Post #2 by bubba22349 » Mon May 21, 2018 4:19 pm
:beer: ok so the Aluminum head looks to be for very Hi Performance build up and racing. :thumbup: :nod:
Wesman07
Post #3 by Wesman07 » Sat Jun 09, 2018 12:10 pm
This we the engine masters episode that got me thinking. They used a 351ci motor... so it not apples to apples. I think we could still put a cross flow head on a stock 300 and see little to no drop in low end power and pick up a lot of Hp.
https://m.youtube.com/watch?v=p1w8OU_8-JM
In-lines we trust
WorldChampGramp
Post #4 by WorldChampGramp » Sun Jun 10, 2018 9:04 pm
Wesman07 wrote:This we the engine masters episode that got me thinking. They used a 351ci motor... so it not apples to apples. I think we could still put a cross flow head on a stock 300 and see little to no drop in low end power and pick up a lot of Hp.
Wesman07 and Forum readers: As you are aware we are definitely planning on Dyno testing all three versions of our cylinder head offerings e.g. the (2) u-Flo street strip, max flow and the x-flow aluminum head. This weekend we jointly decided to build 2 or 3-separate short blocks. 1) hypereutectic piston 9:0-9.5 for street/strip head 2) forged flat top 11.5 to 12.0 with longer event cam for max flow head, & finally the x-flow combination which we will ATTEMPT to retro-fit to the u-flow head to #1 which we don’t anticipate problematic due to the dish (valve clearance wise) BUT anticipate probably having to replace pistons in #2 max flow uhead short block to provide for minimum valve clearance during the overlap cycle. Hope this all makes sense, REMEMBER my promises to all of you dyed in the wool Big Six members NO SHORTCUTS, NO EXCUSES, NOTHING UNDOCUMENTED, NOTHING consider UNIMPORTANT. Like a cleaver cliché I once saw in a men’s room “We Aim to please, so please AIM”
Bruce
:checks:
Users browsing this forum: No registered users and 24 guests
