2018 Contributors:
School me on Pistons
3OOford150
Post #1 by 3OOford150 » Wed Apr 04, 2018 1:03 pm
I am currently in the process of accumulating parts to build my 300. I currently have a brand new set of H519P pistons dished. Can I obtain a 9.0-9.5 CR fairly simple. I plan of putting in this cam in. https://www.summitracing.com/parts/cca-k66-248-4
Or does someone have another piston recommendation to obtain my goal without a ton of machining?
pmuller9
Re: School me on Pistons
Post #2 by pmuller9 » Wed Apr 04, 2018 1:30 pm
There are 2 choices for non-metric hypereutectic pistons that will get you the most compression.
KB/Silvolite 1186H
SpeedPro/Sealed Power H519P
You have the H519P that has a 1.767 CD
The 1186H has a CD of 1.776 so a little less machining on the block deck.
It is not recommended to have a compression ratio higher than 9:1 with the Comp 268 because of the short advertised duration which is the same as the stock 300 cam unless you don't mind running on premium octane pump gas.
It wouldn't take much block deck machining to get 9:1 compression if you use the EFI head
Post #3 by bubba22349 » Wed Apr 04, 2018 1:46 pm
With those pistions the block would need to be zero decked and the head chambers would need to be at about 70 CC's to get a 9 to 1 Static Compression Ratio. Good luck :thumbup: :nod:
jason832
Post #4 by jason832 » Wed Apr 04, 2018 2:34 pm
My 300 has that exact cam and pistons. Carbed head milled 0.060 by PO, 1024 Head gasket, stock bore and block not milled. It diesels most times when I shut it off at full temp on 87 octane. 91 octane runs a bit smoother and lowers the dieseling. Not sure what my timing is at but it is set far enough back that it does not ping under low rpm high load.
Good thing is these pistons come weight matched when bought as a set and the rings I used E-229k came pre gapped and haven't had issues. Note these rings are different materials I think for the first two rings so don't mix them up.
My build https://www.ford-trucks.com/forums/1498 ... heavy.html
pmuller9
Post #5 by pmuller9 » Mon Nov 26, 2018 9:51 pm
Update?
What combination of parts did you end up using?
Users browsing this forum: No registered users and 24 guests
