2018 Contributors:
Need 94 4.9 Torque Specs
94f150rules
Post #1 by 94f150rules » Wed Jul 11, 2018 10:59 pm
In the rush to get all my parts and try to get the whole project done in 2 1/2 days I completely forgot that I dont have a shop manual for the truck. I'm doing a cam swap, an oil pan swap, and while the pan is off I will be checking bearings. So I would need the torque specs and sequence for the upper plenum, possibly the throttle body, Im assuming the lifter cover is just tight, the valve cover and oil pan are snug and then about 1/2 a turn, but I don't know the torque specs for the rockers, the rod and main bearings, and the upper manifold. Does anyone have a link to the information, or maybe know it off hand? I cant order the Ford Manual it wont come on time so I could use any help I could get.
Backwoodswalker375
Re: Need 94 4.9 Torque Specs
Post #2 by Backwoodswalker375 » Thu Jul 12, 2018 7:44 am
Local library should have manuals. I am sure a Google search will come up with the info online. Good luck with your poject.
94f150rules
Post #3 by 94f150rules » Thu Jul 12, 2018 7:46 am
I was on Google most of the night, the problem was I found most specs but I couldn't find a torque sequence, or year to year differences. I don't want to torque something incorrectly.
Users browsing this forum: No registered users and 24 guests
