2018 Contributors:
Intake change - now with pic
GPGoverMPG
Post #1 by GPGoverMPG » Sun Jul 15, 2018 9:36 am
I was running a 2100 carb on a 2v adapter that I made an adapter to mount the 2100 to. Worked much better than stock 1v. Had a spare intake so modified it into a 2v intake and it is way better. The plugs show good color and it pulls nice. Thinking I'm under carb'ed. The engine did pick up a strange sound at cruise RPM, kind of a rattle noise, thinking timing may be an issue. My exhaust system is also way to big for this motor. Still trying to get this dialed in and looking for ideas. Will not let me post photo says board quota has been reached. So I used a saws-all, and it does, to the cut the 1v opening down then ground the opening enough to fit two 1,5" tubes in with the carb mounting plate attached. I also welded a wedge on the bottom of the intake to direct the airflow both directions. not pretty but seems to work great.
71 F350 4x4 Super Duty 7.3 IDI
72 F250 4x4 4speed 300 I6
72 F100 2x 428 Tri Power
2014 SHO
Dr Jay
Re: Intake change
Post #2 by Dr Jay » Sun Jul 15, 2018 5:24 pm
I really want to see a pic! Really!!
Blessings,
Dr Jay
1978 F100 Shortie, Lowered front and rear, 300 .030 over, 300 carb head, Clifford, Holley 390
268 Comp Cam, Cloyes, Fuel Inj. exhaust manifolds, MSD 6A, TOD, 9"
SteveP
Re: Intake change
Post #3 by SteveP » Fri Jul 27, 2018 7:02 pm
My setup is a 2150 carb w/1.21 venturis using a TransDapt 2065 adapter on an Offy C intake with Headman header, 2" pipes and Flowmaster mufflers.
Runs great, sounds sweet.
MechRick
Re: Intake change
Post #4 by MechRick » Sat Jul 28, 2018 3:52 pm
Try resizing images smaller. I use 800 x 600, seems to work, and avoids the 'quota reached' warning.
Stock cam, aluminum cam gear
GPGoverMPG
Re: Intake change
Post #5 by GPGoverMPG » Sun Jul 29, 2018 11:30 am
So here's a picture at last. Resized it about 4 times. Not something I had to do before.
2014 SHO
guhfluh
Re: Intake change - now with pic
Post #6 by guhfluh » Sun Jul 29, 2018 2:15 pm
That's pretty neat. I'm curious why you chose that route over a different manifold?
For the question about rattling, you need to check both the timing and the air/fuel ratio AT the RPM AND vacuum the noise is occurring. You could quite possibly be cruising much leaner now with the settings on this carb, which could be leading to some pinging.
1967 F-250 Crew Cab 2wd, 300 6cyl, T-170/RTS/TOD 4-speed overdrive
240 head, Offy C, EFI exhaust manifolds, Comp 268H, mandrel 2.5-3" exhaust, Edelbrock 500, Pertronix ignitor and coil, recurved dizzy. 200whp/300wtq
Harte3
Post #7 by Harte3 » Sun Jul 29, 2018 5:52 pm
Now that is interesting 8)
GPGoverMPG
Post #8 by GPGoverMPG » Mon Jul 30, 2018 6:59 am
I had the manifold so why not. It really does run better seat of the pants feel. Thinking it may be to much vacuum advance my cruise RPM is right at 2200 which would be all mechanical on top of my initial and an unknown amount of vacuum advance. I may try increasing jet size even though the plugs look good.
2014 SHO
Users browsing this forum: No registered users and 16 guests
