<<< New Site Update >>>
My 300 hits a wall when accelerating.
SinCityLocal
New Member
Post #1 by SinCityLocal » Sun Jul 22, 2018 1:56 pm
I don't have a tachometer yet, so I don't know exactly where it happens. I have a 95 F-150 EFI 300 5 speed. It pulls strong until it flattens out. My guess is 3800-4000 rpm range. More accelerator seems to do nothing. I bought this truck cheap because it had a cracked head. Replaced it and the radiator, and have been driving it for about 6 months. Is this a typical characteristic of the EFI 300, or is there something wrong that I need to look for?
pmuller9
Re: My 300 hits a wall when accelerating.
Post #2 by pmuller9 » Sun Jul 22, 2018 2:34 pm
Peak horsepower is around 3400 rpm
THE FRENCHTOWN FLYER
Post #3 by THE FRENCHTOWN FLYER » Sun Jul 22, 2018 3:57 pm
All 300s, carbed or EFI start to "nose over" at 4000RPM. The best improvement to start out with is a freer flowing exhaust system / muffler.
MechRick
Post #4 by MechRick » Mon Jul 23, 2018 12:15 am
Mine's all done at 4400, and that's a ported head with stock valves. Nature of the (stock) beast...
Stock cam, aluminum cam gear
1986F150six
Post #5 by 1986F150six » Thu Jul 26, 2018 11:31 am
Mine [stock] makes nothing but additional noise after ~3000 rpms. :lol:
Harte3
Post #6 by Harte3 » Thu Jul 26, 2018 1:56 pm
Mine jumps to 4000 rpm as easily as 3000 rpm but the rate starts to slow down at about 4500 rpm and hits the wall at 5000 rpm. That is on a mild/moderate build.
SinCityLocal
New Member
Post #7 by SinCityLocal » Thu Aug 16, 2018 11:27 pm
I recently got and installed a tach cluster. Boy was I way off with my rpm estimate. Tonight, I went for a drive and found that my issue starts at 2500 rpm like clockwork. Pushing past 3000 is nerve racking because it takes so long to get just to that point. It's hard for me to believe this is a fuel issue, but I'm open to any suggestions for where to start my search. The plugs are new and gapped at .044 with new wires, cap and rotor.
Post #8 by THE FRENCHTOWN FLYER » Fri Aug 17, 2018 9:12 am
Melted / plugged catalytic converter?
B RON CO
Post #9 by B RON CO » Sat Aug 18, 2018 9:00 pm
Hi, I like the clogged exhaust idea. I would also make sure the distributor timing is set properly and is advancing as it should. Good luck
1966 Ford Mustang - 289 V8
Users browsing this forum: No registered users and 17 guests
