<<< New Site Update >>>
Points distributors?
3OOford150
Post #1 by 3OOford150 » Mon Nov 26, 2018 7:20 pm
Does anyone know what points distributors will drop in the 300 and run with just a hot wire and a coil. Just in case something in this crazy world happens it would still be able to run.
Re: Points distributors?
Post #2 by bubba22349 » Mon Nov 26, 2018 9:36 pm
You didn't mention what year truck your working on, but assuming it's carb engine from a 1965 to roughly 1984 (or up to 1986 if converted from electronic controlled carb and Distribitor). Then look for a 1968 to 74 point type distribtor from a 240 or 300 six they are the best of the point Distribitors. Good luck in the hunt :thumbup: :nod:
old28racer
Post #3 by old28racer » Mon Nov 26, 2018 11:23 pm
Do you know where one can find a new (not rebuilt) 68-74 points distributor for a 300 motor in a 1971 F250?
If rebuilt is the only way to find one now a days, who has the best one?
3OOford150
Post #4 by 3OOford150 » Tue Nov 27, 2018 8:30 am
You are correct it is a 84 carb converted to non computer. Now the question is will the points distributor have enough umph to be able to spark enough for a 4 barrel setup that I have installed?
pmuller9
Post #5 by pmuller9 » Tue Nov 27, 2018 8:38 am
3OOford150 wrote:You are correct it is a 84 carb converted to non computer. Now the question is will the points distributor have enough umph to be able to spark enough for a 4 barrel setup that I have installed?
Use the points distributor with an MSD 6A ignition system.
The points contacts will last for a long.
It is on sale for the holidays.
3OOford150
Post #6 by 3OOford150 » Tue Nov 27, 2018 8:51 am
I am trying to take any electronics out of the system. So could I just run really hot coil?
pmuller9
Post #7 by pmuller9 » Tue Nov 27, 2018 9:28 am
3OOford150 wrote:I am trying to take any electronics out of the system. So could I just run really hot coil?
Yes you can but the hotter coil will decrease the life of the points contact. The pitted points get ugly.
You can set the MSD box up so if it dies you can quicly disconnect it from the ignition coil and connect the points and power with a ballast resistor to the coil.
The coil can have short leads with a weather pack connector.
There would be two other mating weather pack connectors, one for the MSD system and the other for the points system.
You can plug the coil into either system roadside.
Max_Effort
Post #8 by Max_Effort » Tue Nov 27, 2018 9:58 am
What is the OP worried about? A giant EMD pulse that takes out all electronics?
The idea of daily driving points ignition is a bad one.
If worried, buy a points distributor and leave it in the truck.
You will need a ballast resistor for most OEM coils that were for points ignition.
1986F150six
Post #9 by 1986F150six » Tue Nov 27, 2018 11:41 am
old28racer wrote:Do you know where one can find a new (not rebuilt) 68-74 points distributor for a 300 motor in a 1971 F250?
Just found these: https://www.ebay.com/itm/NOS-1968-1972- ... :rk:1:pf:0
https://www.ebay.com/itm/NOS-Ford-1972- ... :rk:2:pf:0
GPGoverMPG
Post #10 by GPGoverMPG » Wed Nov 28, 2018 9:07 am
A points type distributor is a great trigger for an MSD box. It's working well in my old Pontiac 455SD. Points last a very long time.
71 F350 4x4 Super Duty 7.3 IDI
72 F250 4x4 4speed 300 I6
72 F100 2x 428 Tri Power
2014 SHO
BigBlue94
Post #11 by BigBlue94 » Wed Nov 28, 2018 10:06 am
My 85 300 was running on one with a pertronix kit in it. Plenty of spark to 5000 rpm.
Lazy JW
FSP Moderator
Post #12 by Lazy JW » Wed Nov 28, 2018 1:47 pm
3OOford150 wrote:Does anyone know what points distributors will drop in the 300 and run with just a hot wire and a coil...
Use a distributor as recommended above, and buy a new coil for a Volkswagen air-cooled bug, it does not require any ballast resistor.
A well-maintained breaker point ignition is very reliable.
Post #13 by bubba22349 » Wed Nov 28, 2018 2:17 pm
The MSD 6A box is great! There is another way that is low budget to up grade a point type distribtor for higher output, by using the points to trigger one of the old MoPar electronic ignistion boxes. Your points and condenser will last almost forever as the electrical load is greatly reduced, with the points being used just as a simple switch. In the unlikely case of the electronic control box failure it's a simple mater of swapping the wiring back and regapping so the points can take contol again.
I won't go into all the details of the install other that to say it's very easy and all that info on how to do it are already at (http://www.gofastforless.com). This system can work on about any point type ignistion system, I put this system on my 1956 F350 car transporter in about 1976 (it had a 1965 Olds 425 and Turbo 400 trans). The NAPA chrome control box is what I used it looks just like the one in the picture of the go fast for less electronic ignistion how to. Never had any problems with it and that orginal control box was still on the truck as of 2014 when I lost track of it. The chrome and orange boxes were used on the Dodge and Plymouth Hi Performace engines, just ask for a 1975 ignistion box. Good luck :thumbup: :nod:
Wiring a MoPar ignistion box
http://www.gofastforless.com/ignition/magnet.gif
old28racer
Post #14 by old28racer » Wed Nov 28, 2018 11:36 pm
I have a 1971 F250 with a stock 300" 4.9L motor. Ignition is a stock P&C distributor with the "pink" resistance wire hooked up. I am going to run a Protronix Flamethrower 3 ohm coil.
Can I install a low cost Mopar orange electronic box into this system?
Is there a better Mopar box for dwell control (motor is 5500 max RPM)
Post #15 by bubba22349 » Thu Nov 29, 2018 12:35 am
old28racer wrote:I have a 1971 F250 with a stock 300" 4.9L motor. Ignition is a stock P&C distributor with the "pink" resistance wire hooked up. I am going to run a Protronix Flamethrower 3 ohm coil.
Yes it should work with a Flamethrower coil. The orange or chrome box will work good I don't know of any better one for your combo. Good luck :thumbup: :nod:
Lazy JW
FSP Moderator
Post #16 by Lazy JW » Thu Nov 29, 2018 11:13 am
3OOford150 wrote:I am trying to take any electronics out of the system...
I believe this is the important detail of the original post, which is to create the simplest possible ignition, hence my suggestion of a breaker point distributor with a VW coil. Yes, the VW coil will work just fine with a Ford engine.
All of the suggestions about triggering an electronic ignition are very good ideas, but they do not solve the original poster's goal.
Any engineering endeavor is a compromise.
Lazy JW
FSP Moderator
Post #17 by Lazy JW » Thu Nov 29, 2018 11:19 am
3OOford150 wrote:... will the points distributor have enough umph to be able to spark enough for a 4 barrel setup that I have installed?
Yes, it will run just fine. Don't be scared off by all of the naysayers who don't think it will.
You will need to do the due diligence of much more frequent maintenance.
Lazy JW
FSP Moderator
Post #18 by Lazy JW » Thu Nov 29, 2018 11:23 am
Max_Effort wrote:
The idea of daily driving points ignition is a bad one...
I respectfully disagree. I have driven roughly one million miles on breaker point ignitions. I also still do farm work with horses :wink:
Harte3
Post #19 by Harte3 » Thu Nov 29, 2018 1:43 pm
"I also still do farm work with horses :wink:"
Still using the Fjords?
'83 F150 300, 0.030 over, Offy DP, Holley 4160/1848-1 465 cfm, Comp Cam 260H. P/P head, EFI exhaust manifolds, Walker Y Pipe, Super Cat, Turbo muffler, Recurved DSII, Mallory HyFire 6a, ACCEL Super Stock Coil, Taylor 8mm Wires, EFI plugs.
Max_Effort
Post #20 by Max_Effort » Thu Nov 29, 2018 2:28 pm
I've owned points ignition trucks and owned horses. Both require a lot of maintenance and both smell bad from the tailpipe.
Lazy JW
FSP Moderator
Post #21 by Lazy JW » Thu Nov 29, 2018 2:52 pm
Harte3 wrote:"I also still do farm work with horses :wink:"
Yup :nod: Not as much as we used to now that my daughter is married and has her own family, but the grandchildren are growing up... :D
Lazy JW
FSP Moderator
Post #22 by Lazy JW » Thu Nov 29, 2018 2:53 pm
Agreed! :D
guhfluh
Post #23 by guhfluh » Thu Nov 29, 2018 8:41 pm
Just convert to magneto! :D
Harte3
Post #24 by Harte3 » Fri Nov 30, 2018 1:47 pm
Does a magneto improve the smell emanating from the tailpipe...?
THE FRENCHTOWN FLYER
Post #25 by THE FRENCHTOWN FLYER » Fri Nov 30, 2018 2:06 pm
Harte3 wrote:Does a magneto improve the smell emanating from the tailpipe...?
Doubt it - but they sure get a lot of "OOOHs" and "AAAHs".
sdiesel
Post #26 by sdiesel » Fri Nov 30, 2018 10:03 pm
I'm still in love with my HEI swap, sometimes I just sit an look at how simple clean and efficient she is.
this here b4 I tidied her up and added the ground wire
Users browsing this forum: wallen7 and 13 guests
