<<< New Site Update >>>
Motor mounts
FordThunder
Motor mounts
Post #1 by FordThunder » Fri Jan 11, 2019 4:16 am
Hey guys, I am in the need of new motor mounts for my 1996 F-150.I was curious if you guys have come across any poly-eurathane or higher density over factory type mounts? Everything I have found is for V8 set ups.
Wesman07
Re: Motor mounts
Post #2 by Wesman07 » Fri Jan 11, 2019 8:28 am
Autofab is the only company making what your looking for. I purchased a set a few years ago and they are very nice. I put these to the test many times and they are holding up great. You will feel a little more vibration, but not a significant amount.
https://autofab.com/i-9621949-80-96-for ... ounts.html
In-lines we trust
Fordman75
Re: Motor mounts
Post #3 by Fordman75 » Sat Jan 12, 2019 5:11 am
I'm going with poly leaf spring bushings to build ones similar to Autofab's.
Ted
54 Ford F100/F150 4x4
FordThunder
Re: Motor mounts
Post #4 by FordThunder » Tue Feb 12, 2019 10:16 pm
Nice, that’s what I’m looking for! I have to replace with stock mounts out of necessity at the moment. $30 vs $260. Tires and the exhaust first. Ole Thunder and I thank you!
Users browsing this forum: Econoline, Shorty and 14 guests
