Priming Oil system/pump
F-250 Restorer
Post #1 by F-250 Restorer » Thu Jan 31, 2019 11:08 am
To prime the oil system I simply insert the proper size hex shaft down through the dizzy inlet and into the oil pump, and turn it carefully with a drill, right?
pmuller9
Re: Priming Oil system/pump
Post #2 by pmuller9 » Thu Jan 31, 2019 11:29 am
Yes
But first.
Did you check the cam timing with a degree wheel and dial indicator?
What did you use to advance the cam 2 degrees?
I don't see the timing tab for the harmonic balancer. The one on the timing cover is usually not the correct one.
Bring cylinder #1 up to TDC and see where the timing slot on the balancer is.
Fordman75
Post #3 by Fordman75 » Sun Feb 03, 2019 9:46 pm
I use a old distributor that I gutted and pulled the drive gear off from.
Ted
54 Ford F100/F150 4x4
drag-200stang
Post #4 by drag-200stang » Mon Feb 04, 2019 9:18 am
Fordman75 wrote:I use a old distributor that I gutted and pulled the drive gear off from.
This is the best way of doing it. :thumbup:
It is possible to ding up the shaft bearing surface the other way, I know, :wink: I can mess it up.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
jason832
Post #5 by jason832 » Mon Feb 04, 2019 9:32 pm
To prime my motors I also used an old junk distributor. But I took the grinding wheel to the gear for a few seconds, then put a bolt into the center of the "rotor spot" and put a small weld to hold it in. Grab a drill with a bit to attach to a socket and you're good. Quick and dirty but it worked. I can take a picture of it tmw if you want.
I imagine you could get a long enough hex shaft as well, that would work.
johns3524
Post #6 by johns3524 » Tue Feb 05, 2019 7:30 am
If you can find an EFI/TFI diz, it comes with a shaft that your drill will tighten on...
https://www.ford-trucks.com/g/picture/12727256
86' Bronco, 300-6, .030 over, Crane cam, Cloyes gears, Clifford Intake, Autolite 2100 C3 manual choke, EFI head & manifolds>walker2n1>shorty Magniflow>, Duraspark II, TFI coil, Napa blue box, NP435, NP208F, 3.50's-9"& Dana44ttb, factory a/c
Users browsing this forum: Majestic-12 [Bot] and 23 guests
