<<< New Site Update >>>
crower rod catalog
69rustang
crower rod catalog
Post #1 by 69rustang » Tue Mar 19, 2019 3:22 pm
was looking thru it just for kicks....part # ML93902B3-8 shows 6.7" length 2.015 big end .927 pin but width is chevy-like .941 so if side clearance can be tolerated as some past posts indicate would this be a possibility?
:arg: shouddaworked
pmuller9
Re: crower rod catalog
Post #2 by pmuller9 » Tue Mar 19, 2019 3:33 pm
Yes, you would have the pistons made for tight rod clearance and let the pistons keep the rod centered.
The 2.015 big end is for a 1.888" crank journal. I wouldn't turn the 300 crank rod journal that far.
Besides, you can have custom rods made for the 300 six for a lot less than $2100.
The BBC 2.100" small journal rods fit the 300 crank.
Example: https://www.summitracing.com/parts/olv-c6800smbb8
sdiesel
Post #3 by sdiesel » Wed Mar 20, 2019 12:41 am
as a consideration....
some time back we discussed shaping up the spit hole rods.
there were numerous ideas.
has any progress been made on this idea?
or maybe more to the point.
is there any idea as to when the later rods become unreliable?
as in power numbers etc
the rods seem to be a sticking point
CNC-Dude
Post #4 by CNC-Dude » Wed Mar 20, 2019 9:54 am
They should be avoided for anything but stock rebuilds. The slant 6 has rods that are similar and have had failures well below the 300 HP mark. Use at your own risk.
Users browsing this forum: No registered users and 8 guests
