2018 Contributors:
89 4.9 cam timing
kubotaorange76
89 4.9 cam timing
Post #1 by kubotaorange76 » Thu Mar 28, 2019 7:12 am
I will be pulling and re-gasketing my 89 4.9 over the next week.
Will be doing melling steel/alum timing gears. Which direction do i put the 987g mr gasket cam advance key (driver or passenger looking at front of motor)? Does it go on crank or cam? Thanks
pmuller9
Re: 89 4.9 cam timing
Post #2 by pmuller9 » Thu Mar 28, 2019 9:12 am
The key goes on the camshaft with the offset to the driver's side looking at the front view.
kubotaorange76
Post #3 by kubotaorange76 » Thu Mar 28, 2019 11:43 am
you sir are awesome, thank you for the help
Backwoodswalker375
Post #4 by Backwoodswalker375 » Thu Mar 28, 2019 12:32 pm
Are you sure about that. I thought advancing cam would mean the cam would be "turned clockwise" meaning events would be advanced of cam gear. I may be wrong. Thanks steve
pmuller9
Post #5 by pmuller9 » Thu Mar 28, 2019 1:13 pm
Steve
The cam in 300 six is gear driven and turns counterclockwise
Backwoodswalker375
Post #6 by Backwoodswalker375 » Thu Mar 28, 2019 4:29 pm
Thank you for clearing that up. A good day, I learned something.. steve
kubotaorange76
Post #7 by kubotaorange76 » Tue Apr 09, 2019 1:25 pm
running good
took two weekends, ended up finding a bunch of sludge, pulled down to short block, and back together, cleaned up of course.
i figured what better way to break it in after putting it back together
https://www.youtube.com/watch?v=_H2niS-DGTc
running good, cleaned air temp sensor while i was in there, as well as injectors etc
https://www.youtube.com/watch?v=0uYTEbEEgMI
https://www.youtube.com/watch?v=YkqWDidELeI
BigBlue94
Post #8 by BigBlue94 » Tue Apr 09, 2019 6:04 pm
Nice!
A 10,000 lb toolbox!?
1985 Bronco. 309ci I6, NP435, 4.56 gears, Detroit locker and tru-trac, 4" lift, and 37" swamper tires. The 309 is 9.75:1 CR with a Schneider 140H cam, 4bbl, roller rockers, larger valves, and headers.
1986F150six
Post #9 by 1986F150six » Wed Apr 10, 2019 10:35 am
BigBlue94 wrote:Nice!
Deep well sockets? :lol:
BigBlue94
Post #10 by BigBlue94 » Wed Apr 10, 2019 12:53 pm
Must be made of lead!
kubotaorange76
Post #11 by kubotaorange76 » Mon Apr 15, 2019 8:20 am
just a joke, in actuality it scaled about 3600.
Sad how i even had to get into the gas.
cusz721
New Member
Post #12 by cusz721 » Thu May 23, 2019 7:02 am
Will i have to reset my ignition timing after doing the offset key install?
Post #13 by bubba22349 » Thu May 23, 2019 2:32 pm
Yes! :thumbup: :nod:
Users browsing this forum: 68Flareside240, pmuller9 and 18 guests
