Hedman vs EFI headers
sandboxer
Post #1 by sandboxer » Thu Apr 04, 2019 12:00 pm
I don’t know if specs have been posted, so here goes...
The EFI headers port match beautifully, whereas the Hedman header doesn’t.
sandboxer
Re: Hedman vs EFI headers
Post #2 by sandboxer » Thu Apr 04, 2019 12:06 pm
The EFI is the larger port casting...
sandboxer
Post #3 by sandboxer » Thu Apr 04, 2019 12:10 pm
A comparison shot.
pmuller9
Post #4 by pmuller9 » Thu Apr 04, 2019 1:00 pm
Good catch!
As you know it is not good to have a step down in the exhaust system.
GPGoverMPG
Post #5 by GPGoverMPG » Fri Apr 05, 2019 7:43 am
When I was building my intake I had it mounted to the ported head I'm going to run with the valves removed. It was quite the revelation seeing the transitions. I going to run the EFI manifolds at least for a while guess I'll need to do the same thing. Making sure they line up right when installed will be the challenge with EFI pipes.
71 F350 4x4 Super Duty 7.3 IDI
72 F250 4x4 4speed 300 I6
72 F100 2x 428 Tri Power
2014 SHO
sandboxer
Post #6 by sandboxer » Fri Apr 05, 2019 11:31 am
I’m going to open up the EFI a bit by a 16th all around. That will assure there’s no overhang into the port.
pmuller9
Post #7 by pmuller9 » Fri Apr 05, 2019 12:26 pm
If you use the EFI manifolds will you do a rear mount or engine mount turbocharger?
sandboxer
Post #8 by sandboxer » Fri Apr 05, 2019 7:38 pm
Since the turbo exhaust inlet has a double port entry I will use the separate headers to isolate the pulses into each individual port. At that point I think it will be best to keep the turbo as close to the engine as possible.
Thoughts?
Mdixon300f100
Post #9 by Mdixon300f100 » Fri Apr 05, 2019 9:19 pm
The closer they are, the more thermally efficient it will be. It will spool faster, As the exhaust hasn’t had a chance to cool. Hotter gasses, more volume, more efficient. I’m sure any performance exhaust shop can fab a twin scroll setup, and that’s exactly the route I plan on taking.
pmuller9
Post #10 by pmuller9 » Fri Apr 05, 2019 10:27 pm
sandboxer wrote:Since the turbo exhaust inlet has a double port entry I will use the separate headers to isolate the pulses into each individual port. At that point I think it will be best to keep the turbo as close to the engine as possible.
Thoughts?
I agree.
One of the drawbacks of the rear mount turbo is having to rely on a scavenging pump to return the oil to the oil pan.
The EFI manifolds will save you a lot of work and are far better than the log manifold.
They would be even better if the outlets weren't turned out so far.
Remind me. Are you going to use EFI or a Carburetor?
sandboxer
Post #11 by sandboxer » Fri Apr 05, 2019 10:43 pm
I’ll have the space to make it happen, since there isn’t an engine bay to worry about.
The photo below is in reference to the dual port inlet for those that were wondering.
One header per hole
jgregg13
Post #12 by jgregg13 » Tue Apr 09, 2019 1:35 am
Just a note that if it helps with your plumbing for the Turbo mount, you can use a front EFI manifold on the rear cylinders with a little modification. This raises the rear outlet so the turbo connections might be shorter.
sandboxer
Post #13 by sandboxer » Tue Apr 09, 2019 10:17 am
Sweet!!
Time to look for another set. It looks so much better too.
What size/type turbos are you running?
jgregg13
Post #14 by jgregg13 » Tue Apr 09, 2019 3:29 pm
These are KKK model K14 turbos with a 50mm inlet ID at the compressor. They came off Iveco 2.3L diesel engines. The K14 series is used on a variety of engines from about 2L up to 2.8L that produce about 150 HP +/- . I hope to get around 250 to 300 HP at 4500 rpm max with the twin setup. But not there yet.
pmuller9
Post #15 by pmuller9 » Tue Apr 09, 2019 5:19 pm
jgregg13 wrote:These are KKK model K14 turbos with a 50mm inlet ID at the compressor. They came off Iveco 2.3L diesel engines. The K14 series is used on a variety of engines from about 2L up to 2.8L that produce about 150 HP +/- . I hope to get around 250 to 300 HP at 4500 rpm max with the twin setup. But not there yet.
The actual compressor inducer blade diameter is 38mm as the inlet tapers down.
guhfluh
Post #16 by guhfluh » Tue Apr 09, 2019 8:20 pm
sandboxer wrote:I’m going to open up the EFI a bit by a 16th all around. That will assure there’s no overhang into the port.
Such is what I've done with mine.
1967 F-250 Crew Cab 2wd, 300 6cyl, T-170/RTS/TOD 4-speed overdrive
240 head, Offy C, EFI exhaust manifolds, Comp 268H, mandrel 2.5-3" exhaust, Edelbrock 500, Pertronix ignitor and coil, recurved dizzy. 200whp/300wtq
guhfluh
Post #17 by guhfluh » Tue Apr 09, 2019 8:23 pm
jgregg13 wrote:Just a note that if it helps with your plumbing for the Turbo mount, you can use a front EFI manifold on the rear cylinders with a little modification. This raises the rear outlet so the turbo connections might be shorter.
I've seen mention of doing that somewhere else as well. I'm interested in seeing any more pictures of how the rear manifold fits and clearances if you have any. :)
pmuller9
Post #18 by pmuller9 » Tue Apr 09, 2019 9:31 pm
sandboxer wrote:Sweet!!
The turbocharger compressor inducer diameter for a Iveco 2.3L diesel engine is 38mm.
Great for a stock 300 engine for low rpm application.
You would need two larger turbochargers for what you are doing.
A pair of 42mm turbos would make power on your 240 to 5500 rpm and a pair of 44mm turbos if you want to push the power to 6500 rpm.
sandboxer
Post #19 by sandboxer » Wed Apr 10, 2019 1:17 am
Thanks for the expert advice. I’ll go with my H1C for this time around as we discussed in the other thread. I do like the idea of the twin turbo though. Next time...
Phase3
Post #20 by Phase3 » Wed Apr 10, 2019 8:20 pm
Really like the way this layout worked great idea!
1996 f150 turbo 4.9 OBD2 M5OD 4x4 12 lbs on 93
1997 f350 351w cclb
THE FRENCHTOWN FLYER
Post #21 by THE FRENCHTOWN FLYER » Wed Apr 10, 2019 9:41 pm
Will the downstream exhaust clear the starter?
Phase3
Post #22 by Phase3 » Thu Apr 11, 2019 8:09 am
I think a turbo that had a vband turbine inlet would work great. Then just mill down that heavy flange to accept the mating vband flange and theres enough material there to even change the angle as needed.
1997 f350 351w cclb
jgregg13
Post #23 by jgregg13 » Thu Apr 11, 2019 3:59 pm
pmuller9 wrote:The actual compressor inducer blade diameter is 38mm as the inlet tapers down.
Correct, although I measured the ID of the compressor inlet at the wheel and I get closer to 36mm. I don't know if all K14s have the same inducer size. From a list of K14 car applications it looks like the Audi 2.5L TDI is rated at 140 hp. So what can you expect on a gas engine? That's where I'm thinking 250 - 300 hp on the 4.9L. I have a friend with a chassis dyno, so can report when it's done, but that is a ways away at this point.
I haven't completed the installation and modification of the rear manifold. You have to cut off the front bolt hole ear (which I've done) then I expect to use longer bolts or studs and clamping bars to secure the #4 port. May have to weld a bolt ear to #4 port top like the one on the original rear manifold. To mount the turbos I intend to make adaptor plates 3/4" thick with counterbored bolts through the manifold flange replacing the studs.
And it looks like the downpipes will clear the starter in my application (engine in a '48 Chevy car). It has the small starter. I guess it depends on the clearances in your vehicle. Heat shields, yes. This setup needs to use turbos with integral waste gates.
Post #24 by THE FRENCHTOWN FLYER » Thu Apr 11, 2019 8:37 pm
I like your '48 Chev project, especially how you narrowed the front end. I'm working on a '60 Suburban EMT fire truck and we're using the same unit, un-narrowed.
jgregg13
Post #25 by jgregg13 » Fri Dec 27, 2019 2:44 am
guhfluh wrote:I've seen mention of doing that somewhere else as well. I'm interested in seeing any more pictures of how the rear manifold fits and clearances if you have any. :)
To mount the front manifold to the rear position I first cut off the bolt lug at the very front of the manifold, then milled a couple of flat spots to the top of the front port to the same thickness as the other clamping areas.
Then made a couple of clamping bushings and used studs to clamp up the top of the port.
For the lower clamp at the front port, I drilled and tapped another hole in the head at the exhaust port location just ahead of the existing bolt hole for the intake. I struck water with the new hole so am using a stud with high temperature lock-tite to seal and lock it in the head. Then made a clamping bar with 2 holes from 3/16" flat bar. The new stud and the original bolt are so close together I had to use a socket head capscrew for the second hole for clearance.
Pmelsness90
Post #26 by Pmelsness90 » Sat Dec 28, 2019 11:47 am
Having both the front efi manifolds turbo or not in my opinion just looks way better anyway, also there is a ton of material in the manifolds that can be cleaned up and the collectors can be bored out quite a bit, ill have to measure mine they got opened up.
Users browsing this forum: No registered users and 20 guests
