Yet another cam question
Baldape
New Member
Post #1 by Baldape » Fri Apr 05, 2019 8:22 pm
Hello all,
Been away for a while but having built a couple 300's now( rebuilds mainly, lost count).
I have a theory...
Seems how the 300 has 6 cylinders with 50 cubic inches each I have always ascertained that you should cam a big 6 like a 400 ford which moves the same volume from each cylinder, now I know cyl head design, intake design, and flow characteristics are vastly different, but in terms of cylinder filling, I think it would be a better place to start...
All thoughts welcome!
The return of the baldape
THE FRENCHTOWN FLYER
Re: Yet another cam question
Post #2 by THE FRENCHTOWN FLYER » Fri Apr 05, 2019 8:54 pm
I agree and have been following that theory for years, head flow notwithstanding.
pmuller9
Post #3 by pmuller9 » Fri Apr 05, 2019 10:39 pm
Yes.
Most everyone under cams the 300 six.
There is no loss of low end torque even with .050" durations 30* more than stock.
Furthermore once you get past mid 270s of advertised intake duration the static compression ratio can be increased over 9:1 and still be able to use 87 octane pump gas.
sandboxer
Post #4 by sandboxer » Fri Apr 05, 2019 11:13 pm
Having said that, how much static compression would you safely run with the Schneider 142F?
pmuller9
Post #5 by pmuller9 » Sat Apr 06, 2019 12:25 am
sandboxer wrote:Having said that, how much static compression would you safely run with the Schneider 142F?
I would stay between 9.4 to 9.5 and use 91 octane pump gas.
That is with the cam advanced 2 degrees with the intake lobe center at 108 degrees ATDC.
GPGoverMPG
Post #6 by GPGoverMPG » Sat Apr 06, 2019 7:16 am
It's right where I'm headed. When I degree the cam it's going to be figuring out which offset keys to run in which configuration. Are there straight cut timing gears available? It would make installing the cam simpler. I would rather not be pressing the cam gear on and off a bunch.
71 F350 4x4 Super Duty 7.3 IDI
72 F250 4x4 4speed 300 I6
72 F100 2x 428 Tri Power
2014 SHO
pmuller9
Post #7 by pmuller9 » Sat Apr 06, 2019 9:39 am
GPGoverMPG wrote:It's right where I'm headed. When I degree the cam it's going to be figuring out which offset keys to run in which configuration. Are there straight cut timing gears available? It would make installing the cam simpler. I would rather not be pressing the cam gear on and off a bunch.
No straight cut gears that I know of.
Besides I don't know how that would help.
In either case you are going to have to press on the gear in order to put the cam in the block and see where it is at.
Post #8 by THE FRENCHTOWN FLYER » Sat Apr 06, 2019 9:40 am
GPGoverMPG wrote:...Are there straight cut timing gears available? ...
NO
Pity.
I have a couple of sets of straight cut prototype gears that a member made several years ago. They have an adjustable hub and are infinitely adjustable. It took me a lot of head scratching to figure how to use them but once I did I came to appreciate the beauty of the design. I recently tried to contact the maker but the trail has gone cold.
I would be more than willing to supply photos of these if anybody wants to try to build a copy. Its above my pay grade.
They DO whine.
For more info visit my thread
viewtopic.php?f=2&t=78402
including a short video of the engine start-up.
Mdixon300f100
Post #9 by Mdixon300f100 » Sat Apr 06, 2019 11:57 am
NO
Pity.
They DO whine.
That is a beautiful thing
Max_Effort
Post #10 by Max_Effort » Sat Apr 06, 2019 2:18 pm
NO
Pity.
They DO whine.
I’d think Al Meekins will make them.
https://www.gearsmade.com/?fbclid=IwAR1 ... p68i1Js_kM
Max_Effort
Post #11 by Max_Effort » Sat Apr 06, 2019 2:25 pm
Users browsing this forum: Google [Bot] and 35 guests
