Code 332 troubleshooting steps?
Asa
Location: Tampa, Tallahassee, Hangin out in some Florida woods somewhere
Post #1 by Asa » Fri Apr 19, 2019 10:14 am
'93 F150, Auto, 2WD
Finally got the truck running. Nice and strong. I keep getting code 332 popping up, though. I changed most of the EGR system out when I built the engine, the solenoids on the valve cover are about the only thing I didn't change, but I dislike throwing parts at a problem.
Unfortunately I cant seem to find the actual steps to troubleshoot. Does anyone have them?
Right and Wrong are just words, what matters is what you do
Susie - a work in progress
Clyde - ya mule!
MechRick
Re: Code 332 troubleshooting steps?
Post #2 by MechRick » Fri Apr 19, 2019 10:45 am
332 egr valve opening not detected.
The egr solenoid is on the rear left of the valve cover. Probably a vacuum issue.
Best way to check, pop the round black plastic cover off, start the truck and block the tube on the solenoid with a finger. The egr valve should open and the truck will stumble if the valve is working and all vacuum lines ok.
If that happens, could be a dead solenoid. If it doesn't, check your vacuum source and the line coming off going to the valve.
Stock cam, aluminum cam gear
Asa
Post #3 by Asa » Fri Apr 19, 2019 11:24 am
MechRick wrote:Best way to check, pop the round black plastic cover off, start the truck and block the tube on the solenoid with a finger.
Can you clarify this? Which cover? On what part?
Clyde - ya mule!
MechRick
Post #4 by MechRick » Fri Apr 19, 2019 11:45 am
You will see 3 solenoids at the left rear of the valve cover above #5 and #6 spark plugs. Two of them are identical, those are TAB and TAD for the air injection. The remaining one will have a round plastic cap covering the vent tube with a foam filter inside to keep dirt out of the solenoid.
The round cover can be removed with a pocket screwdriver. Blocking the vent tube with the engine running sends vacuum to the egr valve.
Asa
Post #5 by Asa » Fri Apr 19, 2019 12:12 pm
I've got 2 solenoids.
Clyde - ya mule!
MechRick
Post #6 by MechRick » Fri Apr 19, 2019 12:20 pm
Follow the vacuum line off the EGR valve, it is supposed to be hooked to the solenoid I'm talking about...
Asa
Post #7 by Asa » Fri Apr 19, 2019 12:30 pm
Gotcha.
Clyde - ya mule!
Asa
Post #8 by Asa » Wed Apr 24, 2019 1:06 pm
MechRick wrote:332 egr valve opening not detected.
Yup. Stumbling and trying to stall.
Clyde - ya mule!
Users browsing this forum: blprice74 and 16 guests
