EFI exhaust manifold cast STEEL or iron?
guhfluh
Post #1 by guhfluh » Tue Apr 30, 2019 10:22 am
Anyone ever weld to one? My rear manifold is rusted and worn at the ball socket, and leaks. I'd like to weld different flanges on the ends of the manifolds, but not sure what material they're made from and I'm no welder to begin with. I don't have the equipment to weld or braze an iron manifold properly, but I might be able to hack together something if it's steel...
1967 F-250 Crew Cab 2wd, 300 6cyl, T-170/RTS/TOD 4-speed overdrive
240 head, Offy C, EFI exhaust manifolds, Comp 268H, mandrel 2.5-3" exhaust, Edelbrock 500, Pertronix ignitor and coil, recurved dizzy. 200whp/300wtq
Project300
New Member
Re: EFI exhaust manifold cast STEEL or iron?
Post #2 by Project300 » Tue Apr 30, 2019 11:02 am
I'm not going to be of any help in regard to welding on new flanges, but I'll just give you the heads up that new OEM EFI manifolds can be had on ebay for just about $40.00. I bought a rear one recently but ended up using my old one because I didn't have a big enough hex wrench to remove the plug that's blocking the EGR port - and I managed to get the old one cleaned up well enough to reuse.
THE FRENCHTOWN FLYER
Post #3 by THE FRENCHTOWN FLYER » Tue Apr 30, 2019 12:31 pm
Those are cast iron.
guhfluh
Post #4 by guhfluh » Tue Apr 30, 2019 4:36 pm
Well poo.
The price of a new one isn't a problem; I'd also like to use the manifolds if I ever get to put a turbo on and I don't care for the ball and socket design. I worry about sealing issues under pressure, heat, stress, etc. I also have this one ported already to match my head, which would save some time.
I guess I can still pay someone to weld/braze a flange on if I really want to.
Max_Effort
Post #5 by Max_Effort » Tue Apr 30, 2019 6:31 pm
Cut the ball part off and then mill it for a flat flange.
Post #6 by bubba22349 » Tue Apr 30, 2019 7:03 pm
Don't use any brazing rod on it, it won't stay togeather. :nod:
arse_sidewards
Post #7 by arse_sidewards » Wed May 01, 2019 7:26 am
Max_Effort wrote:Cut the ball part off and then mill it for a flat flange.
This.
I'd personally use the ball and socket though. It's going to be harder to blow it out than anything that uses a flange.
1994 F150 4x4 8ft, engine is basically stock.
66" leafs, extended radius arms, lockers in both ends, nothing special.
guhfluh
Post #8 by guhfluh » Thu May 02, 2019 12:28 pm
Thought about doing that AND using a donut gasket with the stock ball socket pipes. Not sure if that'd be better?
Max_Effort
Post #9 by Max_Effort » Thu May 02, 2019 5:47 pm
Might work, might leak and blow out
I think either a good ball and good socket
Or
A flat milled manifold and a heavy, thick flange and a good gasket... MLS, or one with a good metal ring (like a head gasket).
Sevensecondsuv
Post #10 by Sevensecondsuv » Thu May 09, 2019 1:31 pm
I've had pretty consistent success welding on cast iron manifolds, including on the hot side of a turbo system. I use ER308 filler with with the TIG process (probably any filler with a high nickel content will work). Heat the cast piece up with a torch to at least 500 F before striking an arc. Then weld in small batches, no more than an inch at a time. Hammer peen the welds immediately and thoroughly. Use the torch to keep the remainder of the part hot between welds. Once welding is complete, use the torch to control the cool down rate; the slower the better. Done right it will hold together just fine
Shorty
Post #11 by Shorty » Thu May 09, 2019 6:59 pm
I welder the flange on one of my manifolds when I built my truck ten years ago because I didn't like the way it pointed. I cut it off and cut a wedge shaped section out and beveled it and tacked it, set it on the wood stove for an hour and welded it. I used the lincoln 180 mig with the gas-less flux cored wire in it because that was all I had available at the time. It welded nice and smooth hardly any spatter and has worked without a problem on the truck ever since. Now that I have a tig I would use that with a good high nickel filler rod but the pre heat and good surface prep and fitment are critical.
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
Users browsing this forum: No registered users and 20 guests
