Stainless steel headers - eBay
pmuller9
Post #1 by pmuller9 » Fri May 10, 2019 8:05 am
guhfluh
Re: Stainless steel headers - eBay
Post #2 by guhfluh » Fri May 10, 2019 9:34 am
Not bad. It looks like a Chinese copy of the Headman in 304SS. Wish they had copied the Comp for tube diameter, but still a good deal for what it is.
1967 F-250 Crew Cab 2wd, 300 6cyl, T-170/RTS/TOD 4-speed overdrive
240 head, Offy C, EFI exhaust manifolds, Comp 268H, mandrel 2.5-3" exhaust, Edelbrock 500, Pertronix ignitor and coil, recurved dizzy. 200whp/300wtq
CNC-Dude
Post #3 by CNC-Dude » Fri May 10, 2019 11:38 am
Stainless plus free shipping for that price. Can't beat that.
68Flareside240
Post #4 by 68Flareside240 » Fri May 10, 2019 3:34 pm
I would assume these would also work on a 240 in a 68 F100? I am beginning to lean towards a clifford and some headers instead of the factory setup.
guhfluh
Post #5 by guhfluh » Fri May 10, 2019 3:52 pm
They should. I had Headmans in a 70 F100 w/ 240. Expect some work getting them fitted like any header, but possibly some more being China made.
drag-200stang
Post #6 by drag-200stang » Fri May 10, 2019 6:11 pm
If not a typo and it is 1.5 OD is that not a little small for a 50 ci cylinder ...Probably ok on a low rpm high torque engine.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
Max_Effort
Post #7 by Max_Effort » Fri May 10, 2019 6:21 pm
I can’t comment on those China headers, but I can on the China stainless headers for Harley’s. They are made ok and work ok, but are very thin gauge so they are very hot. The type of stainless deteriorates and will rust.
guhfluh
Post #8 by guhfluh » Fri May 10, 2019 7:20 pm
drag-200stang wrote:If not a typo and it is 1.5 OD is that not a little small for a 50 ci cylinder ...Probably ok on a low rpm high torque engine.
It is on the small side. Same size as the Hedman headers for the 300, which is why I wish they'd have copied the 1-5/8" Hooker headers, as well as the better merge design.
They claim 16ga for the tubing, which is also the same as the Hedmans. Surprisingly the Hooker headers show to be only 18ga.
My experience with Chinese "304 SS" has also been that they will eventually rust some. Many times the head flange used is still mild steel.
I still say it's probably a better deal than the uncoated Headman mild steel for around the same price, or even more for the Headman.
arse_sidewards
Post #9 by arse_sidewards » Tue May 14, 2019 8:46 am
I slap cheapo SS eBay headers on my shitboxes whenever I need to replace an OEM manifold/downpipe with an integrated cat. They tarnish but they don't rust out and I'm highly satisfied with them for the price. I have so many EFI manifolds lying around I'm not sure I'd buy these though.
1994 F150 4x4 8ft, engine is basically stock.
66" leafs, extended radius arms, lockers in both ends, nothing special.
68Flareside240
Post #10 by 68Flareside240 » Tue May 14, 2019 4:17 pm
I don't really care about having the SS look, but I would rather keep them looking as good as possible for as long as possible. Has anyone tried using the VHT Flameproof coatings? Supposedly when cured it's pretty durable. Wondering if it would be worth a shot when I do this rebuild.
arse_sidewards
Post #11 by arse_sidewards » Tue May 14, 2019 4:27 pm
68Flareside240 wrote:I don't really care about having the SS look, but I would rather keep them looking as good as possible for as long as possible. Has anyone tried using the VHT Flameproof coatings? Supposedly when cured it's pretty durable. Wondering if it would be worth a shot when I do this rebuild.
I've used it but not on stainless. I can confirm it's quite durable.
68Flareside240
Post #12 by 68Flareside240 » Tue May 14, 2019 4:36 pm
That's my concern is using it on stainless. I guess I ought to give a call to VHT and see what they say. They have a primer for it as well. I looked at the hedmans that are regular painted and they are about the same price. I would guess that if I went that route I would need to strip the paint before the the VHT. In my limited experience with high temp paint and headers, you're wasting your time. I am hoping the VHT is much more durable. Ford Corporate blue motor with black headers and Offy intake would look really good.
68Flareside240
Post #13 by 68Flareside240 » Wed May 15, 2019 5:42 pm
Called VHT. The recommended a good cleaning and degreasing followed by the primer and then the color. Most of the problems I’ve read about wee people trying to use it on Harley pipes.
Users browsing this forum: sdiesel and 16 guests
