TECH TIP - STORAGE
THE FRENCHTOWN FLYER
TECH TIP - STORAGE
Post #1 by THE FRENCHTOWN FLYER » Sun May 26, 2019 9:47 pm
if you have a block or head you want to store long term see if your local marina has some left-over scrap boat shrink wrap. They often trim off table-cloth sized pieces when covering boats. Wrap head, shrink with a heat gun or torch and stuff will stay clean until ready for use.
sdiesel
Re: TECH TIP - STORAGE
Post #2 by sdiesel » Mon May 27, 2019 12:02 am
excellent tip.
and a low humidity space to storealso.
corrosion paper and shrink wrap, combined, will store my finished parts where in oregon we have high humidity.
also I like to hot tank b4 storing finished parts
Max_Effort
Post #3 by Max_Effort » Mon May 27, 2019 8:28 am
The shrink wrap is a good idea.
For longer term storage and in humid conditions, I use VCI oil (volatile corrosion inhibitor) for storage. I have it in a spray bottle, coat the parts, wrap and seal.
It's also used in the crankcase of engines being stored (all openings must be sealed for it to work)
It washes off easier than spray cosmoline coatings, (but I do use cosmoline on crankshafts)
https://www.amazon.com/Kynetx-Preventiv ... way&sr=8-1
arse_sidewards
Post #4 by arse_sidewards » Tue May 28, 2019 8:03 am
Linseed oil + newspaper + big plastic bag.
sdiesel
Post #5 by sdiesel » Wed May 29, 2019 12:45 am
vci oil...where to get that?. I'll have to look into it.
I love linseed oil, but don't it get hard like the Dickens when dry?
funny story.
Paul M came down a few years ago to fetch some parts he needed.
I had a worn out old block that I knew was .60 over and tired. I had, for some reason put molasses down the holes of this short block, a year or so before, which he decided he wanted. so I had to knock those glued in pistons out with a hammer, without the aid of hot water.
I do not know nor do I wish to know what thoughts might have been going through his head as he witnessed this very low tech, hillbilly taking a hammer to precision parts.
I knew they were junk, he did not, until later examination revealed to him the truths I had known about that blighter of an engine block.
all ended well, the block served his need and I was able to assist, and reduce the massive over-clutter of 300 six parts I have needlessly accumulated over the years.
Post #6 by THE FRENCHTOWN FLYER » Wed May 29, 2019 8:45 am
sdiesel wrote:...
Your experience reminds me. I gotta tell this story:
A supervisor of mine told me early on in his career he had to take one of our used up test cars destined for the crusher to the infield of the test track to park. He asked an unwitting trainee to go with him. Going over the overpass of the track he casually turned the car into the concrete barrier wiping out the entire side of the car, much to the horror of the unknowing trainee who thought he was riding with a psycho.
Its all fun-n-games until somebody gets hurt.
sandboxer
Post #7 by sandboxer » Wed May 29, 2019 9:48 am
arse_sidewards wrote:Linseed oil + newspaper + big plastic bag.
PLEASE DON’T!
Linseed oil heats as it cures and will cause rags and paper to spontaneously combust. Many a garage/shop has been lost to oil soaked rags.
I use linseed oil in my line of work and any cloth or paper that comes in contact with linseed oil goes straight into the wood stove after use. I don’t even set it down on a work station only to be forgotten...
arse_sidewards
Post #8 by arse_sidewards » Wed May 29, 2019 9:58 am
PLEASE DON’T!
When you buy machined steel junk from China it's oiled (sometimes with linseed oil, assuming smell is any indication) and then wrapped in thin paper before being bagged for storage.
I'm not too worried. I paint steel for storage in linseed oil all the time. You need rapid oxidation for linseed oil to get hot. Nothing should be stored in a manner which allows rapid oxidation.
Mdixon300f100
Post #9 by Mdixon300f100 » Wed May 29, 2019 10:35 am
PLEASE DON’T!
I’ve watched linseed oil soaked rags smoke and burst into flames after someone forgot to dispose of them. It can happen in a plastic bag if there’s enough oxygen. I prefer a heavy gear oil or grease for long term storage of parts.
Users browsing this forum: jgregg13 and 14 guests
