Priority main oiling?
Lagerhead
Post #1 by Lagerhead » Wed Jun 12, 2019 9:00 pm
When i freshen up my motor im switchingto a solid lifter cam is possible to do priority main oiling like they do sb fords if sois there a set of instructions or a video
99.5 F350 lowered air ride strong PSD crew cab swb
48 ford coupe cage old school stock car 12.25 to 1 290 cilford cam, cliford 2x2 with webber 38/38,some cool old stock car headers, 240 head with big valves, bbc roller rockers
Max_Effort
Re: Priority main oiling?
Post #2 by Max_Effort » Thu Jun 13, 2019 12:00 am
The oiling is about as close to priority now as your going to get it. It's a simple system that feeds the mains and the lifters at the same time.
THE FRENCHTOWN FLYER
Post #3 by THE FRENCHTOWN FLYER » Thu Jun 13, 2019 8:29 am
The oiling system is very robust. I've had a couple of instances where I lost oil pressure (long stories) and no damage was done when I took things apart to inspect.
CNC-Dude
Post #4 by CNC-Dude » Thu Jun 13, 2019 9:53 am
On Cleveland engines, you tap and install restrictors between the cam and mains. That is mostly for high RPM usage to maximize oil volume to the mains. Really isn't necessary for below 7000 or 7500 usage, but above that it is beneficial.
Lagerhead
Post #5 by Lagerhead » Thu Jun 13, 2019 11:52 am
Thank you for the Input it is one less thing to mess with :thanks:
Users browsing this forum: Pmelsness90 and 15 guests
