Engine is back
68Flareside240
Re: Engine is back
Post #51 by 68Flareside240 » Tue Sep 17, 2019 9:08 pm
Thanks Mr. Paul. Figured $12.99 was cheap insurance. Ordering the ARP studs, retainers, and locks. Currently in more prep work on the valve cover, fuel pump, pulleys, brackets, etc. Got a cool plan for the motors appearance, can't wait til it's done.
68Flareside240
Re: Engine is back
Post #52 by 68Flareside240 » Wed Sep 25, 2019 8:55 pm
Finally got all my parts and tools in to swap the springs and retainers. Noticed on the first cylinder something seems off with valve stem height. These are Comp 942 springs and comp 768 retainers. The exhaust valve seems to be sitting 1/16" lower, which using the same spring and retainers means the spring is more compressed. I left my caliper at home so no way to check height yet but this doesn't seem right at all.
pmuller9
Re: Engine is back
Post #53 by pmuller9 » Wed Sep 25, 2019 10:28 pm
Take an intake valve and an exhaust valve out and measure the valve lengths.
Both should measure 4.810"
It looks like the later 4.750" long exhaust valves got mixed in with the early 4.810" intake valves.
Did any of the stock valves get replaced?
68Flareside240
Re: Engine is back
Post #54 by 68Flareside240 » Thu Sep 26, 2019 9:52 am
These were the valves that were in the head when I got it. I knew it had some head work in the past, so it's highly likely the exhaust valves may have been replaced. I don't recall seeing this before I pulled the old springs and rotators, but then again I don't recall explicitly looking. Of course all of my teardown picture I can't see the valvetrain that closely. Comparing the old springs, the intake and its retainer is at the exact same overall height as the shorter exhaust spring and rotator. I will remember to take my dial caliper when I go this evening. Seems like it's always one step forward, two steps back with this thing.
pmuller9
Re: Engine is back
Post #55 by pmuller9 » Thu Sep 26, 2019 10:41 am
68Flareside240 wrote:Seems like it's always one step forward, two steps back with this thing.
Finding and fixing EXISTING problems is part of the rebuild process and is always a step forward.
Sometimes you have to do a certain amount of assembly to find them.
Keep up the good work!
68Flareside240
Re: Engine is back
Post #56 by 68Flareside240 » Thu Sep 26, 2019 10:51 am
Ha yeah that's true. Just kinda frustrating since I have finally made some good progress, and starting to see this project come together. At least I can say that I have learned a tremendous amount with each problem I have ran into. In the event that my exhaust valves are 4.750", are these the valves that I would be looking at? https://www.summitracing.com/parts/mel- ... /make/ford
pmuller9
Re: Engine is back
Post #57 by pmuller9 » Thu Sep 26, 2019 11:25 am
Yes
Those are the Stellite valves which stand up better to higher temps and unleaded fuels.
68Flareside240
Re: Engine is back
Post #58 by 68Flareside240 » Thu Sep 26, 2019 11:37 am
Good deal. Would I need to take the head back to the shop and have them install the valve, or should I just lap them in place and check the height?
I also found the Enginetech V1633S which is also a Stellite valve and 1/2 the price of the melling. Are these worth a count or should I just go with Melling?
pmuller9
Re: Engine is back
Post #59 by pmuller9 » Thu Sep 26, 2019 11:59 am
I've used Enginetech parts before without any problems.
They should work fine for what you are doing.
I would just lap them in after checking valve stem height.
This is assuming the valve length is the problem.
68Flareside240
Re: Engine is back
Post #60 by 68Flareside240 » Thu Sep 26, 2019 3:30 pm
Indeed. I couldn't think what else it could be though. We will find out this evening.
In other news I got a new tag on the renewal today. Couldn't believe it wasn't already taken
pmuller9
Re: Engine is back
Post #61 by pmuller9 » Thu Sep 26, 2019 3:51 pm
How perfect is that?
Nice!
1986F150six
Re: Engine is back
Post #62 by 1986F150six » Thu Sep 26, 2019 4:03 pm
That license plate is great! Excellent! :thumbup:
68Flareside240
Re: Engine is back
Post #63 by 68Flareside240 » Thu Sep 26, 2019 8:00 pm
Intake on left, exhaust on right. Intake measures 4.740", exhaust is 4.745". As you can see, the keeper location is further down the valve stem. Which would explain why the spring would be more compressed but doesn't explain why the same length valves sit in different positions in the head. Gotta feeling this is worse than I thought.
pmuller9
Re: Engine is back
Post #64 by pmuller9 » Thu Sep 26, 2019 8:16 pm
The valve job was not done correctly.
There may have been exhaust valve seat inserts installed.
The intake valve seats need to be done first so the exhaust valve seat can be cut to the same level.
The top of the valve stems need to be very close to the same height.
Also those are the wrong valves for that head.
Stud mount rocker arm heads (pre 1985) use the 4.810" long valves.
This is an opportunity.
What is the installed intake valve spring height with the present set of parts?
68Flareside240
Re: Engine is back
Post #65 by 68Flareside240 » Thu Sep 26, 2019 8:27 pm
That's what I was afraid of. That was the only thing that could explain the discrepancy I was seeing, in my mind. Exhaust on number two looking like 1.600", intake 1.690". :cry: :cry:
pmuller9
Re: Engine is back
Post #66 by pmuller9 » Thu Sep 26, 2019 8:34 pm
68Flareside240 wrote:That's what I was afraid of. That was the only thing that could explain the discrepancy I was seeing, in my mind. Exhaust on number two looking like 1.600", intake 1.690". :cry: :cry:
Yep, that would cause the problem.
New valves should fix the problem but you now have the option of getting larger valves from SI valves.
They carry the 4.810" long 1.94" intake and the 1.60" exhaust valves.
68Flareside240
Re: Engine is back
Post #67 by 68Flareside240 » Thu Sep 26, 2019 8:53 pm
So best case, I buy new 4.810 valves, they will still have to do a new seat job correct?
Using the Erson 270101, planning on Offy C, Edelbrock 500 manual choke, hedman( or comparable) headers with probable 2.5 duals, would the SI valves be worth the added expense? I mean if they have to be machined anyway, go larger?
pmuller9
Re: Engine is back
Post #68 by pmuller9 » Fri Sep 27, 2019 12:46 am
68Flareside240 wrote: Exhaust on number two looking like 1.600", intake 1.690".
stock intake valve diameter is 1.780" and the exhaust is 1.559"
I don't know what valves those are but certainly not correct and need to be replaced.
That means there is no extra expense in getting oversized valves since both intake and exhaust valves need to be replaced anyway.
The larger valves gives you the chance to get the valve job done correctly where the valve seats are all at the same depth from the head surface so the valve stem tips are at the same height.
You need a machinist that you can trust to get the job done correctly.
68Flareside240
Re: Engine is back
Post #69 by 68Flareside240 » Fri Sep 27, 2019 12:51 am
Those were installed spring height, not diameter. I didn't measure intake but exhaust was 1.559" diameter
pmuller9
Re: Engine is back
Post #70 by pmuller9 » Fri Sep 27, 2019 12:54 am
68Flareside240 wrote:Those were installed spring height, not diameter. I didn't measure intake but exhaust was 1.559" diameter
OK, I must be tired at the end of a long day LOL.
You will need the longer valves to get the 1.700" installed spring height.
Max_Effort
Re: Engine is back
Post #71 by Max_Effort » Sat Sep 28, 2019 2:28 pm
Can you post good clear photos of the valve seats / valve job?
68Flareside240
Re: Engine is back
Post #72 by 68Flareside240 » Mon Sep 30, 2019 4:20 pm
Max_Effort wrote:Can you post good clear photos of the valve seats / valve job?
I will this evening. I went ahead and ordered the Enginetech V1633S as they were on closeout with only 7 left. A shade over $7 a piece. Ordered 12 new Melling MPR306 pushrods and an oil pump shaft. Can easily return if I don't end up using them.
I have a feeling this head will be going back, or somewhere else. Both intake and exhaust valves were very close in length, and the exhaust valve was obviously way shorter installed in the head. Correct me if I am wrong but the only way that happens is the valve seat is a different depth. The exhaust valves keeper was further down the stem which affects installed spring height, not the height of the valve in the head, correct?
pmuller9
Re: Engine is back
Post #73 by pmuller9 » Mon Sep 30, 2019 9:39 pm
68Flareside240 wrote:Correct me if I am wrong but the only way that happens is the valve seat is a different depth. The exhaust valves keeper was further down the stem which affects installed spring height, not the height of the valve in the head, correct?
Both of those observations are correct.
68Flareside240
Re: Engine is back
Post #74 by 68Flareside240 » Tue Oct 01, 2019 11:42 pm
I would so assume it is not supposed to be that way. I meant to take pictures of the valve seats the other night, but I pulled the valves and just kinda lost motivation and quit fooling with it. I know they're screwed up. Not making excuses for the shop, but they do about 80% just cylinder head work, and 98% of those are "just do enough to keep it running" due to financial considerations. I talked to them about fixing whatever was wrong as I wanted it right, but I'm thinking it was passed through as a teardown magnaflux, deck it, etc. Put it back together and keep on trucking. I know the head was "worked" about 500 miles before I got it. What all was done I'm not sure but I known it was done cheaply. I don't think the shop I went to even touched the seats and valves, it was all done prior. Probably gonna take it to them tomorrow go through what all needs to be done. I've gotten to know these guys pretty well, they've been doing this a long time. I know they can make it right. I think it was just a misunderstanding. I'm glad I decided to replace springs or I'm not sure id have ever caught it. One thing I did do was compare new pushrods to old. The old ones were significantly worn down on the tips. I'd be willing to bet they are originals and this motor has had a TON of miles put on it in it's life. I'll post some pics and let you know what I find out. Once again thanks for being a sounding board fellas.
Max_Effort
Re: Engine is back
Post #75 by Max_Effort » Wed Oct 02, 2019 7:52 pm
68Flareside240 wrote:I would so assume it is not supposed to be that way. I meant to take pictures of the valve seats the other night, but I pulled the valves and just kinda lost motivation and quit fooling with it. I know they're screwed up. Not making excuses for the shop, but they do about 80% just cylinder head work, and 98% of those are "just do enough to keep it running" due to financial considerations. I talked to them about fixing whatever was wrong as I wanted it right, but I'm thinking it was passed through as a teardown magnaflux, deck it, etc. Put it back together and keep on trucking. I know the head was "worked" about 500 miles before I got it. What all was done I'm not sure but I known it was done cheaply. I don't think the shop I went to even touched the seats and valves, it was all done prior. Probably gonna take it to them tomorrow go through what all needs to be done. I've gotten to know these guys pretty well, they've been doing this a long time. I know they can make it right. I think it was just a misunderstanding. I'm glad I decided to replace springs or I'm not sure id have ever caught it. One thing I did do was compare new pushrods to old. The old ones were significantly worn down on the tips. I'd be willing to bet they are originals and this motor has had a TON of miles put on it in it's life. I'll post some pics and let you know what I find out. Once again thanks for being a sounding board fellas.
I wanted to see if a quality valve job was performed. If it looked as a good multi angle job, with proper seat widths were done, then I’d ask you to check contact of the valve to the seat.
If all was good, then it wouldn’t be the worst thing to have a different installed height on the exhaust. You’d just have be sure spring force and pushrod length were still Ok (or compensate).
Often in the production, “get er done” shops, they just hit the seats quick with a 45* and slap it together.
Now to sink the exhaust seats to the proper depth and then bring in the proper valve job is a lot of work with stones. The job will go a lot faster with a cutter system, such a Serdi, VGS20, etc.. or a combo of cutter and stone.
68Flareside240
Re: Engine is back
Post #76 by 68Flareside240 » Fri Oct 04, 2019 9:03 pm
Not sure if you can tell in the second picture, but the valve seat isn’t seated against the head
Max_Effort
Re: Engine is back
Post #77 by Max_Effort » Sat Oct 05, 2019 10:26 am
68Flareside240 wrote:Image
It looks like the most recent work was a quick grind with a stone on the 45* seats. They might have hit the angle below the exhaust seat with a 60* stone. The whole exhaust seat doesn’t show full contact from the stone. And the 45* seat areas look wide from here.
You have hard seats intake and exhaust. They are probably in all the way, it can look like that from the old valve job and throat. I can’t tell if that’s a square sharp cut? The seats are older work and I would've expected them to have torched and fallen by now if they weren’t in tight and making good contact with the head casting.
It looks like the guides were replaced previously with conversion guides, hopefully they are still good.
It will probably run ok like that, but it isn’t great. If you want it better, You need to find a shop that can put a nice multi angle profile on the seats, and get them all at the same height.
The shop that did the work, probably does this all the time, gets by with very few complaints or problems and thought they did a good job and gave you a good deal.
It’s typical of a $796. Job to do all that work. They can only spend so much time on things.
pmuller9
Re: Engine is back
Post #78 by pmuller9 » Sat Oct 05, 2019 4:58 pm
The intake seat is definitely deeper in the head than the exhaust seat.
The intake seat insert looks like it is too low in the head
I'm not sure I would want to cut that much off the exhaust insert to get equal seat heights.
Using the longer exhaust valves would be an easier fix.
Seat width should be .040".
The bowls need to be blended into the seat inserts.
68Flareside240
Re: Engine is back
Post #79 by 68Flareside240 » Sat Oct 05, 2019 5:26 pm
Well is it fixable? Would new seats and valves fix it? I really want to keep this head as this truck is all original. I know this truck isn't that valuable but from a sentimental standpoint from me. I learned a week or so ago a good friend of mine's grandfather bought this truck new. I'm the 3rd owner. I'd like to get it right but keep the original head.
Max_Effort
Re: Engine is back
Post #80 by Max_Effort » Sat Oct 05, 2019 6:34 pm
68Flareside240 wrote:Well is it fixable? Would new seats and valves fix it? I really want to keep this head as this truck is all original. I know this truck isn't that valuable but from a sentimental standpoint from me. I learned a week or so ago a good friend of mine's grandfather bought this truck new. I'm the 3rd owner. I'd like to get it right but keep the original head.
From here... there is plenty of exhaust seat insert to cut. Whoever installed the seats, drove them in and just cut the 45*, then a bottom 57* or 60*. Those seats are hard and it takes forever to grind with stones.
I’d have no issue cutting the exhaust deeper, putting a top and bottom angle and blending into the bowls.
The intake just needs the minimum cut, with top and bottom angles to narrow the seat and blend into the bowls.
And you certainly could use longer valves.
68Flareside240
Re: Engine is back
Post #81 by 68Flareside240 » Mon Oct 07, 2019 12:50 pm
Just got off the phone with the shop. Pretty much what you fellas said. They touched everything up and knew I was running a hydraulic cam so didn't see enough discrepancy to affect what I was wanting to do. I already have the exhaust valves, springs, and retainers, just need to order new intake valves. Taking the head over Wednesday to drop it off and get it fixed correctly.
sdiesel
Re: Engine is back
Post #82 by sdiesel » Sun Oct 13, 2019 12:59 am
give us after pics just like u gave us b4 pics.
we check up on their work.
there is so little that I can call knowledge on this topic, so its imparitive, I have a good shop do the work.
like u are doing. your almost there!!!!
68Flareside240
Re: Engine is back
Post #83 by 68Flareside240 » Fri Nov 01, 2019 5:27 pm
Just wanted to update, I haven't dropped the head off. I am waiting to order valves before I take the head back. I have kinda held off intentionally so I can focus on fixing some things in the engine bay that I need to address. No sense in a gorgeous motor stuffed in a shabby engine bay. But the plan is to get the head to them with the new intake valves and let them install them. I did mock up number one cylinder with the new exhaust valves, new comp springs, and installed spring height is dead on at 1.700" I am thinking since the intake was the one installed too deep, they will have to get new seats for intake, and fit the valve to them.
I did just cash out some credit card points for $400 in Amazon gift cards so that I can order the Offenhauser C. They have it at 376.99, pretty much what everyone else has it for. Essentially free to me. I plan on using the edelbrock 500, manual choke, vacuum secondary carb, likely the AVS2 model number 1904. I think that's the one with the annular boosters. I know the Offy DP requires a certain configuration, but the open plenum of the C shouldn't require that, correct? Is it just my OCD nature that it needs to have primaries/and secondaries left and right, not front back? Does it not matter? I am thinking ahead to throttle and choke cable routing and was wondering.
68Flareside240
Re: Engine is back
Post #84 by 68Flareside240 » Tue Nov 05, 2019 11:58 am
Ordered a set of Melling V1120 intake valves. Hope to get it all dropped off tomorrow.
Got all the wiring out of the engine bay so I can get to work with the wire wheel on 50 years of crust. Only rust through is the area under the battery tray. Not enough in my mind to warrant a new inner fender. I believe I can fab a piece up to fix it. Going to pull the steering column and rebuild it and shifter mech. New fuel and brake lines while I have it out. Work is quickly piling up, but might as well do it while I am there.
Ordered the intake, and I believe I found the answer to my question in that it doesn't matter direction on the C. Hoping my dad and Santa get together on getting me a carb.
As for ignition, I plan on keeping the original Autolite distributor, but replacing the points system with the Pertronix ignitor II and coil. Any pros/cons to this system?
68Flareside240
Re: Engine is back
Post #85 by 68Flareside240 » Fri Jan 17, 2020 10:41 pm
Picked the head up last Wednesday. Things look much better. Intake seats were pretty deep, so probably going to have to use some 0.030” shims to get the spring height right. If it ever quits raining, I can touch up the paint and get this thing back together!
THE FRENCHTOWN FLYER
Re: Engine is back
Post #86 by THE FRENCHTOWN FLYER » Sat Jan 18, 2020 9:53 am
OOOooo.
I would be a little uncomfortable with those valve seats based on the photos you posted. On the exhaust seat alone I see pits in the seat, blueing left on the seat, and it even looks like the grinding stone did not fully contact the circumference of the seat.
I hope I am wrong in my assessment.
If I were you I would use a little lapping compound on the valves to verify that there is:
a) full circumferential seat contact
b) the seats are of proper width
c) the valves are properly placed on the seats
If my worst fears are confirmed I would find a different shop to finish the job correctly.
I can't tell you how mad it makes me when I see shops do shoddy work on unsuspecting / unknowing customers.
Good luck with your project.
68Flareside240
Re: Engine is back
Post #87 by 68Flareside240 » Sat Jan 18, 2020 1:09 pm
Well for the low price of free, I may have gotten what I paid for. I think some of what you may see is artifact from me cleaning the head up. There was a little surface rust I was cleaning off the face and I think the inconsistencies you see is a smear of oily debris on the seat. I didn’t recall seeing anything like pitting when I looked at all the seats , but I didn't spend too much time looking it over. Just removing the spots of rust and reoiling, until the weather breaks and I can clean it up and touch up the paint.
I will try to post more information when I can. Appreciate y'all keeping me straight on this project.
pmuller9
Re: Engine is back
Post #88 by pmuller9 » Sun Jan 19, 2020 11:24 am
How even is the valve stem tips now?
Please go over the valve seats lightly with lapping compound as FTF suggested to check the contact area on both the seats and the valve
surfaces.
The contact width should be around .040"
68Flareside240
Re: Engine is back
Post #89 by 68Flareside240 » Sun Jan 19, 2020 11:53 am
They are even with the naked eye, I haven’t installed and measured yet. I see what FTF was talking about with the machinists dye. It’s difficult for me to tell if I smeared what was remaining or there was not even contact. The seats all look concentric. I will most definitely do some valve lapping as suggested.
I’m not sure if it’s a regional problem or what, but every shop that I spoke to, when I told them what I was doing, I got responses of “we only work on race motors”, “I don’t do that kind of work”, etc. Makes it hard to find a reputable shop.
Motorboy
Re: Engine is back
Post #90 by Motorboy » Sun Jan 19, 2020 5:18 pm
Thanks to all who have been contributing to this thread. I'm learning a lot, and I appreciate it. I'm looking to get together something similar over this spring and summer. (My shop has low ceilings so i cant pull my truck in. As a result some of my work is weather dependent. It's too cold in PA right now.) Keep up the good work!
Econoline
Re: Engine is back
Post #91 by Econoline » Mon Jan 20, 2020 10:23 pm
68Flareside240 wrote:They are even with the naked eye, I haven’t installed and measured yet. I see what FTF was talking about with the machinists dye. It’s difficult for me to tell if I smeared what was remaining or there was not even contact. The seats all look concentric. I will most definitely do some valve lapping as suggested.
Look for the fleet/diesel/industrial then speed type shop. The fleet/industrial is the bread and butter of the operation. Unless you have a good relationship you've got to be patient with most machinists ime. I try not being pushy but they will take forever if you let em when they're swamped with regular work from their main customers. It's a fine line sometimes. If you let them know where you're coming from and what you expect and they agree to do it and are worth a damn, then they'll do it in a semi-reasonable amount of time and do it right. If they can't do it right after you already went over what you were after either they just don't like you or they're hacks. Imo, they're hacks either way. If you don't want to do it just say, right? Machinists take pride in their work. It's one of the highest artforms imo.
I hope they did a good job for you.
It ain't gonna fix itself
68Flareside240
Re: Engine is back
Post #92 by 68Flareside240 » Sun Jan 26, 2020 11:24 pm
Well I spent about 6 hours today lapping valves, because based on my results, it hadn’t been done. At all. FTF was correct in his assessment, as usual!
Anyways, after reading a good bit on the subject this week, I achieved what I felt was a pretty good valve seat. I did it the old fashioned way, stopping frequently, to clean and check progress. It was a worthwhile experience, but I am damn sure gonna feel it tomorrow. Glad I only had 6 cylinders worth of valves.
Installed number 1 intake and exhaust and the valves were level. Stopped there because I didn’t have my mic. Hoped to get it all checked tomorrow and then clean it up and get this hurdle behind me. Once again, thanks for the help gentlemen.
Users browsing this forum: bubba22349 and 54 guests
