Bad fuel pump?
Krussell
Bad fuel pump?
Post #1 by Krussell » Fri Aug 02, 2019 2:43 pm
Completely inconsistent. Yesterday it ran fine, today it runs like crap. It's been having problems starting when it's facing up hill, vapor locks constantly, hesitates when accelerating, etc.
Then I took the fuel line off to redirect it because I thought the gas may be getting boiled, and fuel dumped all over the ground. Now I was on a fairly steep hill, so I thought that could be the cause of. But I changed the fuel pump a couple of years ago and I don't think it dumped the fuel like that.
So best guess, do you think it's the pump? Bad diaphragm? I mean this pump isn't very old, but it's maybe not the best.
68 Ford F-100
300cc I6
Manual choke
MechRick
Re: Bad fuel pump?
Post #2 by MechRick » Fri Aug 02, 2019 3:01 pm
What;s the year-make-model of the vehicle?
Stock cam, aluminum cam gear
Krussell
Re: Bad fuel pump?
Post #3 by Krussell » Fri Aug 02, 2019 4:31 pm
'68 Ford F100
68 Ford F-100
300cc I6
Manual choke
Soldmy66
Re: Bad fuel pump?
Post #4 by Soldmy66 » Fri Aug 02, 2019 5:07 pm
When did you last replace the fuel filter?
Shorty
Re: Bad fuel pump?
Post #5 by Shorty » Fri Aug 02, 2019 6:57 pm
could there be an issuue with fuel tank vent? could build pressure or vacuum depending on temp changes or run time. Run it with the gas cap loose for a bit and see if there is improvement. I used to have a tractor like that,it would run rough after extended run time if the fuel cap was tight, but would run all day with the lid loose.
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
Wesman07
Re: Bad fuel pump?
Post #6 by Wesman07 » Fri Aug 02, 2019 8:54 pm
I’d start with fuel pressure and work back. Test one thing at a time and watch the gauge. All of what is mentioned is possible.
In-lines we trust
Krussell
Re: Bad fuel pump?
Post #7 by Krussell » Fri Aug 02, 2019 10:05 pm
So I changed basically every fuel component out from the fuel cap to the float last year since I bought a new carb and didn't find out that the float was leaking until about two months ago.
I changed that fuel filter out about two months ago. I changed that gas cap out last year. That was one of the first things I did after changing out that carb and it kept flooding over.
I would think that fuel pump would be fine since it's not very old and I haven't used it since the truck hasn't run since I put it on, but I tend to find really bad new parts somehow.... Like a brand new carb with a leaky float.
Thanks for all the suggestions. And I did buy a pressure regulator, but haven't put it on yet
68 Ford F-100
300cc I6
Manual choke
Re: Bad fuel pump?
Post #8 by bubba22349 » Fri Aug 02, 2019 10:56 pm
Did you get the float level set correctly? If it’s still flooding out after changing the float out, it’s not likely to be a bad fuel pump. Next check the needle and seat for damage or if a piece of trash holding it open. Testing the fuel pressure is a good move. Good luck :thumbup: :nod:
Users browsing this forum: Google [Bot] and 35 guests
