Remflex 3080 One Pc Gasket question
old28racer
Post #1 by old28racer » Fri Jul 24, 2020 10:27 pm
I have used Remflex intake/exhaust one pc gaskets before on a Chevy 194 inline 6 and was very happy with the fit & quality. Just want to make sure the Remflex 3080 is the correct gasket for my 240 / 300 head that has a Clifford aluminum intake and long tube headers? Have others on this site used this gasket on their 240/300 heads? Comments.
Bad Day Racing Is Better Than A Day In The Stands :mrgreen:
wallen7
Re: Remflex 3080 One Pc Gasket question
Post #2 by wallen7 » Sat Jul 25, 2020 9:13 am
Yes that is it.
BigBlue94
Post #3 by BigBlue94 » Sat Jul 25, 2020 3:16 pm
Ive soured on the remflex. Took 3 orders to get one that wasnt damaged (poor package design). Then I had a blowout on one exhaust port because there wasnt enough gasket there to seal with my clifford longtubes. I welded some bead on the headers to seal better.
When i removed it to wrap my headers, I went with a flatout brand gasket. Its significantly less fragile and has upwards of 3 times the sealing surface area available. Its much thinner, though, at maybe .093". It does this while port matching to the head and int/exh manifold and headers pretty darn well. Needless to say, ill be buying these from now on.
1985 Bronco. 309ci I6, NP435, 4.56 gears, Detroit locker and tru-trac, 4" lift, and 37" swamper tires. The 309 is 9.75:1 CR with a Schneider 140H cam, 4bbl, roller rockers, larger valves, and headers.
old28racer
Post #4 by old28racer » Sat Jul 25, 2020 4:12 pm
What is the part number of the flatout brand gasket you used?
sdiesel
Post #5 by sdiesel » Sun Jul 26, 2020 12:50 am
There is a "SQUISHINESS" FACTOR to the remflex that needs some practice to get right, and I too have had mismatch. but , for uneven or warped surfaces, I've worked with nothing better. Especially intake /vacuum issues.
For headers reflex is ideal.
BigBlue94
Post #6 by BigBlue94 » Sun Jul 26, 2020 1:03 pm
old28racer wrote:What is the part number of the flatout brand gasket you used?
8085S
https://www.summitracing.com/parts/fog-8085s/make/ford
old28racer
Post #7 by old28racer » Mon Jul 27, 2020 12:18 pm
Thanks for the part number.
Users browsing this forum: Google [Bot] and 22 guests
