Just a little 200 with a turbo (specs, videos, etc)
thatblue_67stang
Post #1 by thatblue_67stang » Sun Oct 07, 2018 7:20 pm
Im not sure if im known on here yet but i have a 1967 I6 turbo 200. Car is loads of fun. Thought i would share the specs, build process, and some videos. What does everyone think? I know there is alot to improve on so share your thoughts. it works perfectly rn so im not making any drastic changes.
Specs:
Ford 200
Stock cam
stock pistons
stock rods
stock non adjustable rockers
302 valve springs
ARP headstuds
Felpro head gasket
rings gapped (i forget what i gapped it to)
milled of stock log intake
custom made short tube intake manifold
custom log style turbo manifold
Holley 2300 350cfm made to accept boost
Quick Fuel Billet Carburetor Metering Block 34-8QFT
#53 size power valve jets
#70 main jets
ebay (dont hate, if you dont push them they work dreams) turbo 50mm running 5psi going to 10psi
ebay intercooler
MSD 6al-2
MSD boost timing master (pulling 1* per psi just to be safe)
Summit racing HEI distributor (set to 12* initial)
Holley 4-65 psi fuel regulator
Summit electric fuel pump
ebay aluminum radiator
G-Plus Oil cooler
IMAGES OF THE PROCESS
VIDEO
https://vimeo.com/293849460
https://vimeo.com/293854160
Last edited by thatblue_67stang on Mon Jan 21, 2019 10:20 pm, edited 2 times in total.
Brayton
1967 Ford Mustang Coupe
200 Inline 6 Turbo Charged
Image Image
Re: Just a little 200 with a turbo (specs, videos, etc)
Post #2 by bubba22349 » Sun Oct 07, 2018 8:16 pm
Nice build looks like a lot of fun too! :thumbup: :nod:
fast64ranchero
Post #3 by fast64ranchero » Mon Oct 08, 2018 9:45 am
Nice to see another modified log head. Looks like it runs ok!
63 Ranchero,1965 Mercury Comet Convert V-8, 1978 Fairmont small six, mill'd off intake, 62-1 ET 12.332 @ 123.49 mph (gone)
thatblue_67stang
Post #4 by thatblue_67stang » Mon Oct 08, 2018 12:42 pm
fast64ranchero wrote:Nice to see another modified log head. Looks like it runs ok!
Runs great. It's alot of fun
Brayton
Image Image
JackFish
Post #5 by JackFish » Mon Oct 08, 2018 1:56 pm
Wow, nice work! :thumbup:
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
gus91326
Post #6 by gus91326 » Mon Oct 08, 2018 5:34 pm
That is awesome! Looks well engineered. What octane do you run? Do you know your CR? Very well executed!
thatblue_67stang
Post #7 by thatblue_67stang » Mon Oct 08, 2018 6:22 pm
gus91326 wrote:That is awesome! Looks well engineered. What octane do you run? Do you know your CR? Very well executed!
I'm running strictly 93. And as for cr I have no idea but its stock compression
Brayton
Image Image
bmbm40
Post #8 by bmbm40 » Mon Oct 08, 2018 7:51 pm
Yes good quality build. Really enjoyed the videos and pics,should be inspirational to those considering a turbo.
thatblue_67stang
Post #9 by thatblue_67stang » Mon Oct 08, 2018 7:53 pm
bmbm40 wrote:Yes good quality build. Really enjoyed the videos and pics,should be inspirational to those considering a turbo.
Thank you feels good to get all this praise. Didnt know I was doing something that alot of people where scared to do. I'm 20 just building my dream car
Brayton
Image Image
fakundo__92
Post #10 by fakundo__92 » Mon Oct 08, 2018 11:52 pm
Very good construction How many horses are you driving you know? :thumbup:
thatblue_67stang
Post #11 by thatblue_67stang » Tue Oct 09, 2018 8:26 am
fakundo__92 wrote:Very good construction How many horses are you driving you know? :thumbup:
I'm guessing like 125-150 but what really matters is torque. Yah horses means I can go fast but torque means how quick I can get there lol. But this thing is a torque machine rn. Hope to turn it up soon
Brayton
Image Image
fast64ranchero
Post #12 by fast64ranchero » Tue Oct 09, 2018 12:51 pm
I suspect your guessing of numbers is wrong unless you are running really low boost. Generally I go by, 15hp per lb. of boost + 20 to get to zero intake manifold pressure. 90hp stock, plus 20hp (just getting intake pressure to 0 psi) plus 15hp x boost psi.. usually comes out close.
thatblue_67stang
Post #13 by thatblue_67stang » Tue Oct 09, 2018 2:34 pm
fast64ranchero wrote:I suspect your guessing of numbers is wrong unless you are running really low boost. Generally I go by, 15hp per lb. of boost + 20 to get to zero intake manifold pressure. 90hp stock, plus 20hp (just getting intake pressure to 0 psi) plus 15hp x boost psi.. usually comes out close.
I'm only running 5psi as of now. And a 200 has 75 hp to the wheels stock. So I'm guessing about 150
Brayton
Image Image
fast64ranchero
Post #14 by fast64ranchero » Tue Oct 09, 2018 3:48 pm
Sounds like it is well sorted now, as you increase boost if you have any questions let us know.
PS my milled off intake setup made 444 whp and 501 ft lbs. It was also blow through carb setup a lot like yours is.
thatblue_67stang
Post #15 by thatblue_67stang » Tue Oct 09, 2018 3:50 pm
fast64ranchero wrote:Sounds like it is well sorted now, as you increase boost if you have any questions let us know.
WAIT WHAT. youre telling me u made 444 and 501 that would be a dream. how much boost did u run and was it stock internals? if you have a facebook or anyting i would love to chat instead of just messaging back and forth on this
Brayton
Image Image
thatblue_67stang
Post #16 by thatblue_67stang » Mon Jan 21, 2019 10:15 pm
UPDATE:
As of this winter im throwing a 8.8 in with 3.73 gear. im also widebodying it and slappinng some 315s on the rear. then i hope to turn it up to about 10psi. it should be a beast. here is a render of what its going to look like. i am also making my own k member and custom suspension for my car with custom piece i have designed myself to hold a fully adjustable upper control arm to the stock mounting holes
Image[/quote]
Brayton
Image Image
