Doofnoil":1owgju39 said:
I want and will get 11-12 sec. DAILY DRIVEN from a 200, who has done this or why won't it happen?
The buick 231 cube guys can do it easily, but they have heads that are
far and away better then the factory log head.
You NEED a non log head. And MPFI will make the 400 HP mark MUCH easier to reach than trying it with a carb.
Look at the Aussie head, the Argentine head (either cast iron or aluminum) or wait for a while until Mike comes out with his aluminum head. You could also take a stock log head and have the whole side milled off and build your own custom intake and exhaust.
matt1967":1owgju39 said:
a member on here cranked out 450 HP out of a draw thru turbo setup 200 I6 with the log head
"Drag200 stang" car is NOT steetable at all. It is full race only.
Mustang Boy":1owgju39 said:
will is running 11's and he only has 283hp at the wheels...... with a streetable car
That's a 250, not a 200. And it isn't their daily driver.
