Something of a ramble follows..
Two valve per cylinder engines can cope with cams over 270 degrees if the ports aren't too big. I think a too big port is when it is any more than 90% of intake valve area on a wedge or canted valve engine with intakes as big as they can be. A benchmark is 2.7 sq in for a 1.96" intake valve (265 Valiant), or 3.3 sq in for a 2.19" intake valve (early 351C 4v). That's 89 to 87.6%. Any bigger, and the air speed drops, and big cams really don't help build the air speed at low engine speeds. If there is a big plip in the engine torque at about 2500 to 2800 rpm in our I6 engines, then the ports are as big as they should be for the combination, and more is to be gained by camshaft optimisation and port shape.
Its always a great sign in a turbo engine if the cam is too big...it most likely means your cylinder head is flowing too much
Wasn't it Sam Blumstein from Chevy Off Road and Marine who said "There are no wrong cams, only wrong engine combinations!
The 292 degree cam would work fine only if the ports were restrictive, and the turbo was sized to suit. A free breathing head creates problems with 'cammyness' compared to a log head. With a great cylinder head, you always have to come down on cam duration compared to an optimized turbo combination with a poorer flow.
When the cam is larger, and you
a) Reduce capacity
b) OR Increase VE (head flow, improved inlet intercooling air flow efficiency, improved manifolding with better apprach and larger ports, , or more efficent exhast, or go to port on port carburation)
c) OR Reduce lob seperation
d) the rocker ratios are increased (SOHC Fords have aggressive ratios up in the 1.8 to 2.0, much above the 1.5, 1.6 or 1.73:1 used in I6's.. while 4 valve per cylinder DOHC machines are much milder and this means they have to have much less duartion and lift)
these cars always get cammy earlier.
The duration issue is based on the way in which the above factors conspire against the turbo charger graph.
On Pinto 2000 cc engines, the point at overcamming for a turbo is often right at 292 degrees at 12 psi with a large T04 turbo and where the LSA is less than 110 with a stock 2-bbl intake...any more, and the engine falls flat and fails to build bost. Camming up just a little to over 300 degrees results in a bad surge, and awfull transitional response.
The wrong cam with just a smidgen too much duration and too little lobe centre angle, and the car is a dog. Backing off the cam helps massively.
On an I6, VE is lousy with a stock 1-bbl head, much better with a 2V head, and out-of-sight with the CI head. As soon as you improve VE, the car instantly goes cammy. This is always the case with a freeer breating cylinder head, as the air speed drops, and messes up transitional response.
As for the DOHC Ford, take a cruise in an F6 verses the XR6 Turbo. Stomp on anyone of these mutthas out of a corner at 1500 rpm, and the F6 has lots of turbo lag, yet the XR6 Turbo has none. That's because of the improvement in volumetric efficeincy , and it always hurts low speed off boost to boost transition.
In the case of the CI alloy head, a 292 cam will be a problem because of the port sizes. The stock Iron or 2v heads can run largers cams than a freer breating head.
This is a rule found by Rob McGavin's land mark book Modifying Your Mini for Modern conditions. After Mc Gavin poored over Vizards air flow theory, he found that BMC allways undercammed there high performance 998, 1071, 1275 engines whenever the better high flow Weslake designed heads were used. That's because a 'cammy' engine is where air speed goes subcritical and produces a drivability problem. So cars like Aussie Minis with 1098 cc twin carb plodders, or 1275 MG Metros had quite aggressive cams, but the Cooper S variants only had really mild cams, seamingly hardly worth the effort. BL race cams were off the planet, but seldom did the hot 648 profile cams ever yield the goods unless the lobe separation was special. The sucessfull ones were hybrid blends.
Same with the beloved Cleveland 351. First versions with the little 2V head had like 256 degree cams just like the cooking Windsors yet had massive wide open throttle power with awesome low end torque, and then the big port 4V HO ones with too much duration, like the early 310 degree Phase II GT, with 10.7:1 compression, were absolute hairy beasts to drive. As soon as the duration was dropped just 10 degrees to 300 degrees, the engine became wounderfully elastic. By the time hydraulic cammed 280 degree 1973/74 Cobra Jet 351 4V versions with a paltry 9.1:1 compression, they were very tame, and ended up being the standard Pantera engine for a while.
So if you have a stock log head, a wild cam will surfice. If its a better flowing head, a wild cam will screw it up a bit. The critical point for non turbos comes when you are over 270 degress with a great head, and about 280 with a small port head. For a turbo, you can add 10 degrees to these, and still have good streetable combination.
Most issues with carb size, turbo and camminess due to duration were expounded very clearly in the two SOHC Ford/A-Series Vizard books, and they are noticed much earlier on small 1.0 to 2.3 liter engines with Holley and Weber series carbs and turbos than on our big old iron lumps 1.1 to 5 times the capacity.
