2018 Contributors:
How much N2O can a stock 200 i6 handle?
rustymav1974
Post #1 by rustymav1974 » Wed Feb 23, 2011 8:47 pm
I'm talking with very rare use. I'm gonna swap my maverick either to a bored 250 or a 302 (haven't decided yet) but not for like 7 months or so. Has anyone ever tested it?
Re: How much N2O can a stock 200 i6 handle?
Post #2 by xctasy » Tue Mar 01, 2011 1:48 pm
Yes, you can use up to 40 to 100 hp worth depending on base tune before the engine explodes. Honourable mention, a blue Sprectre Performance TBI 1970 Maverick 200 cube, 15 second quarter mile, see the Classic In-lines pages. Another guy in Australia does 13.5s with a stock 200, just a 500 cfm Holley and a 100 hp nitrous shot in a 1962 Falcon
If you turbo charge your 200 with about 14 pounds of boost, and strip out the extra weight in an already 2600 pound Mustang, you'll do 200 hp as well. Our member Linc200 ran at 13.5 seconds of 1/4 mile in his 84 Stang with 82 I6 conversion. More than that, the pistons will then pop, the car will stop, and the jaws of the crowd will drop, and your budget will then have to prop a rebuild.
With good leakdown from stock pistons and better fuel delivery and a stratergy to keep out of detonation, a 200 six could foreseesbly do 11 second quarters for 1000 runs without major tear downs like the Aussie 3.3 and 4.1's do.
Generally, rebuild any stock 87- 97 hp (120 hp gross) 200 engine with better cam, head, reduced advance ignition curve, and then add 1.47 times its power in nitrous. So if you used, say, a Classic Inlines head and got 200 hp with a 465 cfm 4-bbl and 274/274 Clay Smith cam, you could then go up to a maximum of 294 hp with nitrous. That's almost a 100 shot. If you keep it stock, then 87 hp becomes 127 hp, or a 40 hp shot
rustymav1974
Post #3 by rustymav1974 » Wed Mar 02, 2011 11:25 pm
Awesome. Do you know how I could get my hands on a nitrous plate? And after I get my plate do I just hook it up like I would any other Nos system? Thanks
64 200 ranchero
Post #4 by 64 200 ranchero » Mon Oct 01, 2018 1:04 am
I ran a 90 shot for a month on cast Pistons. I ended up cracking one after holding the nitrous for too long. Now I run the 90 shot with forged Pistons and a correct nitrous gap with water/meth injection and it handles it effortlessly. I think I can actually go higher, but how much can the crank, rods, and block handle?
60 ford ranchero 200 tri power, modified c4 trans, performance ds2 distributor, msd 6, 3 stage retard, weber ict's, 8" rear end with spool, 3.40 gears, CI dual out header, Flowmaster, 90hp wet nitrous kit.
Users browsing this forum: 95FordFleetside and 9 guests
