Ok I've done lots of reading here and on other forums about turbo charging. I think my buddies and I have enough fab skills to mount and intercool the turbo. I know there is enough experience here to help me get it tuned. The question is-Is it possible to have a reliable turbo boosted six? Most of the ones I've read about were either full blown race cars, Will and Linc, or not enough long term info given, Bort 62.
I have a well ported large log head with a two barrel thru a Clifford adaptor, but will direct mount soon. Somewhere around 8.5 to 1 compression. I'm installing a 274/274 112 cam. To take advantage of this cam I need to up the compression to 10 to 1 or so, or go turbo. The motor has some miles but runs great and doesn't use any oil. I know I should rebuild before I put a turbo on it but....I probably won't.
I'm getting a Holley direct mount plate from Classic Inlines to direct mount the carb. I can then go any two barrel carb, Autolite, or Holley and with another adaptor a Weber. I see that the Holley 350 seems to be the carb of choice, but I wonder if one of the Autolites might be better. I would mount whatever we think is the easiest to tune.
So, I'm a manufacturing engineer, I'm friends with a proffesional welder and have lots of friends in our machine shop. You guys have the expertise. What's the verdict, can I run a turbo on a semi-daily driver. I drive it during good weather.
Bob
Bob
