djfalcon10":2t2ppgdg said:
well.i would love to get 300hp or more at the rear wheels. boost i would guess at 7psi max. i am puting it in my 65 falcon wagon. love to have it run 12's...... that my goal,
Lets say around 400 hp at the crank.
The 240 would need head porting with larger valves along with a matching cam to get 400 hp using low boost.
Head work is still a good way to go even if you were doing a 300.
You can meet your power goal using less boost.
Consider using a 300 non-efi head in either case.
The combustion chamber is larger allowing you to use a flat top piston in the case of a 240
or a shallow inverted dome piston in the case of the 300.
Also the larger chamber has less valve shrouding and doesn't require as much work when installing larger valves.
The 240 connecting rod (without the oiling hole in the big end) makes a good performance rod after the beam has had the forging parting line removed, then polished and shot peened. Install ARP rod bolts and then have the rods resized.
With the 300 head and 240 crank, you can use forged 302 sbf flat top pistons with a 1.6" compression distance to get around an 8.5 compression ratio with a zero deck height.
When using the 240 rods and 300 crank, it would be best to use a custom piston with a 1.2 compression distance and around a 25cc reverse dome dish.
Custom pistons using 2618 alloy are around $90 a piece.
The short pistons used in this combination weigh a lot less than stock and the piston skirt does not protrude as far out beyond the bottom of the cylinder bore at BDC as the stock pistons do.
