I've posted in turbo forum a few times about my typical competing projects: returning to the track with a L6 contender and continually upgrading my daily drivers' small block sixes. Competition building whether NA or Forced Induction can't easily (safely) be done inexpensively, but good running small block six daily drivers can be dramatically performance upgraded fairly inexpensively.
Mcinnes and related turbo info made it apparent a true turbo-drag performance setup will need bottom-up build consideration specific turbo demands and related expenses. As a learning/test platform the current project is to build a "bolt-on" turbo system that will fit any (my typical) small block six..
So Far- most easily affordable used turbo's are not for so-called slow turning-high torque tractor gas engines and virtually no modern systems use the draw-thru arrangement since modern Fuel Injection system can make turbo conversion so much easier. I like the simplicity (in theory) of Carb'd draw-thru simplicity for low-boost/percentage HP increase it but requires specific turbo and control considerations.
The early 80's Buick pushrod/carbd 301 V6' turbo has L6 spec' similarities for turbo application, I'd appreciate useful comments (other than hood clearance 8) )
the mockup for consideration, :
thanks
thanks
