80ford100":27r27qk1 said:
I am thinking about supercharging my daily driver 300. The current setup is as goes, 300 inline 6 stock compression, pistons, crank, comp 268 cam, ported and polished head with screw in rocker studs, stock rockers, comp cams hydraulic lifters, stock push-rods, offy dual port intake, heddman headers, summit 650 cfm carb, stock duraspark 2 ignition, and stock oil pump. I'm new to the supercharging thing and need to know what I will need, what supercharger, how to plumb it, if it will run with my current setup, what will work with 87 octane gas, and basically anything else that I can't thing of that I might need.\
I've had the taste of power and I want more, so I thought, put a blower whine under the hood!! :mrgreen:
Thanks, John
The Eaton M112 supercharger from a Ford Lightning is a good match and can be found fairly cheap on Ebay.
The Eaton M112 is a roots type supercharger and is good for 10 lbs of boost.
you can make an adapter to mount the supercharger on your present manifold.
It will take some work to get the drive belt aligned between the crankshaft pulley and the supercharger pulley and to make a support for the idler/tensioner pulley and drive snout of the supercharger.
The 6th generation TVS Eaton superchargers are a lot more efficient and will run a lot more boost but are a lot more expensive.
There are the twin screw superchargers, Whipple, Kennebell, Lysholm that are very efficient and very expensive.
All the above superchargers are positive displacement superchargers and will produce boost from low rpm on up.
Then there are the centrifugal superchargers, Vortech, Procharger, Paxton.
These units build boost proportional to the increase in rpm.
You decide at what RPM you want max boost to occur and the supercharger's drive ratio is selected to meet that target.
You can think of it as a belt driven turbocharger.
It is also easy to add an intercooler to this type of system.
As been discussed a stronger than stock piston is highly recommended unless you like to take chances.
A 2618 aluminum alloy custom piston is recommended for this type of application.
Piston prices went up in 2014 and a 2618 alloy piston may be as high as $125 a piece for this application. It was around $100 a piece.
I just paid $125 each for a set of Diamond pistons for a V8 turbo application.
You are looking at an 8:1 compression ratio.
The 1965 - 1968 (no oil hole) connecting rods are a stronger option.
The beams should be polished and shot peened then the rod resized using ARP bolts.
The longer 240 rod from that year range allows a shorter and lighter piston.
As also previously stated, detonation under boost will damage the engine so a big "NO" on the 87 octane gas.
Use the highest octane pump gas available.
