Blow through I presume? A draw-through setup would obviously work since the carb never sees boost. As for if it will hold 7psi, I have no idea. However, you could setup a simple test to find out. Find a way to block off the inlet and outlet of the carb (perhaps with it still mounted to the intake) with a air hose attachment fixed into one end. Pressurize to 7 psi using an air compressor and look for leaks. I did this to test an intercooler, granted it was a bit easier to seal off the ends with couplers and a pvc cap.
Sorry I couldnt help more. Elaborate on your setup and someone might chime in.
