Hello everyone,
I am in the process of putting my 300 turbo back to life after 15 years of sleep. The truck is a Bronco "86 that I swapped out the 5.0 EFI and put in the old 300....now with AOD. Turbo is most likely from Saab 9000-Garrett.
Engine is most likely from 1975 and have distributor with vacuum canister.
Ignition is MSD6
BTM 8762 and tach adapter 8920
Fuel is computer controlled MAF sensor and 750cfm throttlebody with 4 injectors.
Coil MSD blaster
o2 sensor
exhaust temp sensor
intercooler
new spark plugs NGK
new wires MSD-8.5mm, cap and lock
My concern is the setup of the vacuum. Do I hook the BTM 8762 directly to manifold vacuum and no vacuum to the distributor canister, or do I have both connected at same time?
I also have problem with boost. When driving uphill and boost start, the truck chokes and die. This might be related to timing, but not sure.
thanks,
Rellinn
Ignition is MSD6
Coil MSD blaster
o2 sensor
exhaust temp sensor
intercooler
new spark plugs NGK
thanks,
Rellinn
