221 turbo piston
xpcoupe221
Im looking for some .040 low comp turbo pistons for my 221. Im not really chasing enough hp to warrant custom forged was more so hoping to find a better lighter dished version than a std replacement. Any help would be great. Thanks
I'm only seeing cast replacement piston also.
Here is a good rundown on possibilties. A lot of info towards the bottom of the thread.
viewtopic.php?f=3&t=69393
Otherwise the best option is to call Autotec directly and price a 4032 alloy piston.
The advantage of custom is you can get the piston compression height for zero deck clearance without having to machine the block deck.
Second, you can get the exact dish volume needed for the correct compression ratio.
