pmuller9":2xrhvkbj said:
You're fighting 3 things here.
Very late closing intake valve, excessive valve overlap and a very low DCR (5.6)
If you were to go open loop you would find very little help with torque above idle since the manifold vacuum is very low under any load anyway.
Secondly the engine requires manifold pressure just to maintain a steady state highway speed.
It take 4 psi at 2000 rpm to maintain 60 MPH so you can't be open loop at low rpm without loss of power and making turbo response worse.
Like I said earlier, the only band aid that I found to give any results worth the effort was to advance the cam but it is still a band-aid and doesn't address the root cause of the problem.
If you want the maximum width power band there can't be any miss matches in a closed loop system.
The intake and outlet control pressure. Ideally, Id like 67StraighSix to welded the chambers of his cylinder head to 48 cc, and keep the cam he's got.
This is a loop I learned from Buddy Ingersoll, Ak Miller and David Vizard. Look at the turbos adiabatic cycle, and be okay with some off beam methods. Dick Johnson had a problem with not getting the help he needed from Ford in 1988 with his Sierra Cosworth RS500. He used two engine management systems, and created a car that made 60 hp un-turboed, and 500 hp boosted, and then switched the fuel deliver systems between each state. The huge reduction in DCR was taken car of by the turbo being feed fuel like a jet turbine to boost it. This is the AR Anthony Rodriguez idea. You can lean fuel out and then slug it suddenly, like the excess fuel factor in nitrous.
Don't be afraid to try the CT Colin Townsend method. If the fuel deliver map and advance is fine, then play with Upstream Inlet and Downstream Exhaust to make transitional boost. The DCR and Cam, they stay the same.
The low compression is the only bad guy here.
guhfluh":2xrhvkbj said:
Adding a second wastegate will not help. At all. Even if you call it a throttle body.
Its not a wastegate. Its a
flow inducer. A feet per second increase by area reduction from an upstream throttle body that gets released when the engine hits target boost. The intake air is harsh and impinges on the normal adiabatic cycle. The turbo impellor is loaded. The exhaust inducer is forced to spin the loaded intake to a higher boost level.
The full article. Colin's turbo was sized too small on a 265, but the concept is the same
https://www.autospeed.com/cms/a_107764/article
The exhaust can be restricted to gain boost. By a cut out.
Either way, it comes on boost quicker without hurting the ludicrously high power output.
Aussie AIT guy have been doing this stuff for years.
And you guys want to change the cam.
I clean floors. Boost pressure goes up when the intake gets restricted or the outlet from the motor gets blocked.
Mitsubishi did this on the Turbo 2.0 Starion and Turbo 1.8 Cordia to improve boost by blocking a really nice exhaust with a ghastly 1.5" plate on the exhaust silencer.
