Turbo Sizing
I'm planning a turbo build of my '66 200 and I was offered a T35 72/80 turbo in a trade. I wanted to pick your brains about the viability of this turbo in my application.
The motor is completely stock currently and with the addition of the turbo, will be a two barrel carb of some sort (blow thru), new camshaft, and a free'er flowing exhaust. That's the extent of the build plans though. Thanks for any input you guys can provide.
Can't find any info on a T35 72/80
The important spec is the compressor inducer size or the inside diameter of the compressor inlet just in front of the compressor blades.
With the stock head, meaning no porting and other head modifications, a 46mm turbo is the largest for your build.
It will produce around 250 hp at 15 lbs of boost with a good intercooler.
