thatblue_67stang
Under WOT my carb leaks fuel from the accelerator arm shaft (the shaft that holds the butterflies). it leaks from the opposite side of where the linkage goes. im going to rebuild that shaft but was wondering if there is anything i can put in there to make it not leak. i have a holley 2300. is there any orings or special seals that are made for boost.
