DIY electric vacuum pump
64 200 ranchero
Post #1 by 64 200 ranchero » Sat Jan 19, 2019 9:45 pm
I have finally found a way to make a dependable electric vacuum pump for use with power adders. A bmw 2001- 2006 e46 smog pump bracket, a bmw 1998 - 2001 740il smog pump, and this dc motor speed control from eBay https://rover.ebay.com/rover/0/0/0?mpre ... 3050271784
Use a 90* universal coolant fitting between the stock pcv valve cover grommet, connect the fitting to the pump bottom inlet with heater hose, connect the top pump outlet to any universal breather tank.
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
pmuller9
Re: DIY electric vacuum pump
Post #2 by pmuller9 » Sat Jan 19, 2019 10:48 pm
Thanks, Nice Find!
How much vacuum does it pull at full output without boost?
64 200 ranchero
Post #3 by 64 200 ranchero » Sat Jan 19, 2019 11:00 pm
Not sure, but it's enough to pull the oil cap in by itself at idle when turned up all the way. Do not run it at full power for long, it will burn out the pump. I have mine adjusted to about 3/4 power, it still pulls pleanty of vac.
pmuller9
Post #4 by pmuller9 » Sat Jan 19, 2019 11:48 pm
It would be fun to build an interface using a 1 BAR sensor that pugged in where the potentiometer is on the motor controller.
This way you could set the unit for just a few inches of vacuum and let it self regulate.
64 200 ranchero
Post #5 by 64 200 ranchero » Sat Jan 19, 2019 11:53 pm
That's a great idea
64 200 ranchero
Post #6 by 64 200 ranchero » Sun Jan 20, 2019 4:44 pm
sdiesel
Post #7 by sdiesel » Thu Jan 31, 2019 11:18 pm
a fellow i do business with does the IDI diesels.
he plumbs a separator into his intake and a drain tube from separator back to oil pan. the drain back is valved, says it works just fine.not very scientific though.
uses 2 breather caps on valve covers.
64 200 ranchero
Post #8 by 64 200 ranchero » Mon Feb 04, 2019 8:17 pm
A separation tank would be nice. A lot of oil vapor condisates inside of the pump. It doesn't seem to be a problem though.
sdiesel
Post #9 by sdiesel » Tue Feb 05, 2019 2:40 pm
pleased my disjointed writing made enough sense for you to comment.
what i meant is the vacuum source is the intake hose pre turbo,is plumbed with a line running to the seperator mounted externally to the engine. the drain back is hooked to the bottom of the seperator which is filled with steel wool.
on a diesel a vacuum is created by the velocity of air.
on a gas rig, would this work?
or is vacuum too hi on off throttle situations?
Post #10 by xctasy » Wed May 15, 2019 12:39 am
See thesameguy's Mann Diesel Truck Pro Vent 200
viewtopic.php?f=22&t=75973&p=585077#p585077
