Turbo 4.9 f150
Here are some pics I found on my Instagram
All finnished up with the new combination. Just waiting for a buddy to come over so I can get the cam broke in
Just made these plates up to mount twin T25 (K14 actually) to the Ford manifolds. They are 5/8 plate, tapered, drilled and counterbored for socket head cap screws. I drilled out the threaded stud holes in the manifolds to 15/32" and used 7/16 cap screws and nuts. I shortened the heads of the 7/16 screws a bit so I didn't have to counterbore too deep. If anyone is doing this I can supply the pattern file to plasma cut the plate to shape.
Good job. Those should spool quick! I just started a new project. I'm putting my motor in a 98 ranger. This thing is going to be a beast. And I'm putting a pair of t3t4's where the radiator was. I have 1000hp worth of compressor now.
