kjacobson351
Hi, first post here but I've been lurking here for years. I've got a unique situation and I'm in the early stages of planning a blown 200 build and would like to work out some details.
First I am located in Japan, there are no junk yards or anything to pull parts from over here. Everything must be imported.
The application is a 1961 Econoline that I imported last year. I imported and installed a long block that I intend to keep stock and I am going to build the block I removed specifically for this application. Both blocks are 7 main 200s.
I have a 1968 Mustang back home with a B&M 144 Roots blower. I plan on robbing the blower for this build.
I am going to import a 250 2v head and get the manifold to run the blower on from Aussie Speed.
I shot some quick emails to Aussie Speed and I am pretty sure that they custom make the crank pulleys for this application so hopefully I can find a way to get the ratio close to 1:1 - 1:2 overdriven instead of nearly 2:1 like the v8 pulleys are set up for. My goals are not to have huge power or to win any drag races. I just want to reliably run the huffer and have a unique build. I am trying to see how low my compression ratio will go using stock dish type pistons with the 250 2v head. My goal is to have a static compression ratio of 7.5 to 8 and to run about 6 pounds of boost (If the proper pulleys can be made).
Can anyone tell me what kind of compression ill be looking at with stock type pistons and an iron 2v head swap?
does the 2v head require 2v specific headers / manifolds?
Is there anything I am missing here? Assuming there is overlap in my cam could I get away with running (and wasting) more boost if I cant find a proper pulley setup?
Thanks for hearing me out, I am definitely still in the planning stages and am picking up the parts I need for the build as I find them. These questions are starting to keep me up at night so I figured I would get them off my chest. Help me not be a laughing stock, I get laughed out of my shop on a regular basis due to the baby 1 barrel, when all the other inlines nissans over here have triple weber setups. lol
