Crane cams, opinions please
fordmuscle83
The cams are called blue racer from crane are there are three different specs.
Im looking at this one: 292 adv dur, 215@0.50thou and 0.49lift, LSA 111
Comments:Good idle with lope. Good all round performance with basic intake and exhaust modifications, good mid-upper RPM power and torque.
BASIC RPM 2000-4800
The main reason for this cam is its much cheaper than the other names and the spec seem about spot on apart from lift. Why is it so low compared to other companies if increase lift only increase power and torque at that point, or is there a benefit from it?
Single rail four speed and 2.92diff in a lightened xf (maybe 12-13:1 comp and water/meth injection) with 500 progressive holley with basic head work.
Pete
