I've run foul of not measuring enough - the XM Falcon I've been working on has hit a snag. The tired 170 motor has been removed with the owner's wish for a 221 to be installed in the newly painted bay. Naturally, I had trouble finding a 221, but was able to find a 250 pre crossflow in good condition, so got the owners nod to use that instead - unfortunately, this later model motor won't bolt up to the XM bellhousing!
What are my options for engine replacements? I don't want to use the later model style motor/gearbox assemblies (160mm between the top bellhousing mounting bolts centre to centre), as this will require also changing the Z bar clutch (on the older style bellhousing with 120mm spacing between the top bellhousing mounting bolts) over to hydraulic, along with gearbox mounting and yoke differences.
What model and capacity Falcon motors will bolt up to the original XM bellhousing? Also do the original XM 144/170/200 6 cylinder engine run a factory sandwich plate between the motor and gear box?
Many thanks in advance - I thought I played with "old" XA falcons, but these XM's are in another generation to my knowledge, so I'm floundering a bit with info to suit
Clint
Clint
