Cross Flow Engine Parts Source USA
Ranchwagon
I am looking for a parts source for my 250 Cross Flow. Need Distributor Cap and Rotor, Valve Cover Gasket, Misc items
Even if I have to order from Australia, anyone have reliable sources.
Richard
Richard
What head and intake manifold?
The early iron headed Cross flow from 1976-1980 has a distributor rotor which is Dodge D series 6 cylinder truck.
The cap is specific to the year, but it is actually Bosch made which was used in Aussie Mopar and Holden sixes, with with the Bosch Duraspark 1980 Cross flow 1-BBL alloy head distibutor being different to the earlier points Bosch item.
Space is at a perimum, but you can fit a 1968-1973 Duraspark I cap to a Duraspark II US distributor if you have the 1-bbl cross flow.
Anything else, easy to get. I've gotten these parts before anmd sent them stateside, not expensive at all.
PM me,
