1985 X-Flow in a 1962 Ranchero?
papawfalcon
I have a 1985 x-flow in my 1962 Ranchero . The question is the steering which maybe the same as XK or XL. If anyone has put this type of motor in an early Falcon and had any problems with the stock steering. And is there a motor or block mount that works better than the other. It seam a little close from oil pan to the center link. Thanks Ken.
If the center link is close to the oil pan, you could flip it like they do for V8 swaps in the roundbodies.
In order to flip the center link, the holes that it attaches to have to be retappered on the opposite side.
Hope this helps.
