It should be a C4 in it, if you can post some pictures of your trans I could verify that it is. Yes these old transmissions used the Ford type F fluid. Good luck
Hi, try posting your question on the tranny index. We used Type F back in the day. I still use it in my 66 Mustang C4. The tranny men will know if any of the new fluids are usable. I have used Mercon on my newer stuff, but I don't know if it is compatible with the older cars. Good luck
