Inspection Plate for xflow with C4
Yes, the 260/289 pre 1965 C4 might have the same one.
These had the 160 teeth flex-plates, and were the same as the US C4 used in the Australian Falcon, which is essentially a C8 casting dating back to the 1968 Australian 221 in line six Fairlane.
1964–1965 Select Shift, 24/24 spline, castings: C4, C5. 5 bolt bellhousing.
I actually found the plate that came with the xflow.
It matches my xflow perfectly however it only covers the top half.
It looks like there should be another piece to cover the lower half?
Yeah, two piece. I m not sure on the lower. I suspect the US Fairlane part will be the same as all he other C4s including the Aussie ones used on the high mount starter in line small sixes.
The starter motor was in a different spot though.
