np435 is in
kirkallen143
np435 is in
Post #1 by kirkallen143 » Wed Jun 13, 2007 8:44 am
Just stuck the np435 behing the 200 last weekend, me and Jerry (bigjhoov). Went in like it was made for it, only modification was to re-drill crossmember mounts. I did have to shorten my back drive shaft, only because previously I had it lengthened for the suspension lift. This swap adds about 2" to the drivetrain length. I used the aluminum plate adapter and my original inline six intermediate housing (had to cut the yoke nut threads off the back of the np435 output shaft so it would mate up). And the way it drives now, I should have done this a long time ago.
Kirk
fb71
Post #2 by fb71 » Wed Jun 13, 2007 3:13 pm
you've got a heck of a work crew helping you there! Do you keep them around because their little hands can get to the tough-to-reach bolts easier?
Jim DeAngelis
kirkallen143
Post #3 by kirkallen143 » Thu Jun 14, 2007 9:06 am
fb71 wrote:you've got a heck of a work crew helping you there! Do you keep them around because their little hands can get to the tough-to-reach bolts easier?
How did you know? And they work for candy, too. Yeah they are mine, all four of them. The oldest, not shown, was in the bronco giving orders of course.
Kirk
fb71
Post #4 by fb71 » Thu Jun 14, 2007 2:18 pm
I knew because I have two little helpers myself! And yes, the 9 yr old does enjoy ordering around the 6 yr old... :D
Jim DeAngelis
chad
Re: np435 is in
Post #5 by chad » Mon May 09, 2011 9:56 pm
[quote="kirkallen143"]Just stuck the np435 behing the 200 last weekend, me and Jerry (bigjhoov). Went in like it was made for it, only modification was to re-drill crossmember mounts. I did have to shorten my back drive shaft, only because previously I had it lengthened for the suspension lift. This swap adds about 2" to the drivetrain length. I used the aluminum plate adapter and my original inline six intermediate housing (had to cut the yoke nut threads off the back of the np435 output shaft so it would mate up). And the way it drives now, I should have done this a long time ago.
Kirk
Boy, a 3.3 w/that tranny :twisted: The nice n lite BII had a 2.8 V6, wonder what that would B like w/your NP?
66WarPony
Re: np435 is in
Post #6 by 66WarPony » Thu May 17, 2012 11:54 pm
Hey bro, I'm about to drop an NP435 in my own Bronco and was wondering if you have any tips for me? I do have a few ?'s for you and was hoping you could help: I noticed that your tranny has a shifter with 2 bends, did it come like that or did you do that (I have only 1 bend in mine as it stands right now); can you tell me where you bought the adapter/spacer was purchased; how did you redrill the adapter housing and what was the shape of the housing (was it an upside down house shape, like the one I have); did you have a HEF tranny to start? I'm really itching to get this thing in, any info would be much appreciated.
Present: '89 Bronco XLT, 302 (no I don't like it, I'm just stuck with it at the moment), Bassani Shorty's, 4" Lift, 33" Grabbers
Upcoming: Hoping to get back in the EB game if the opportunity presents itself
"If you want to know about something, read a book." - Dad
chad
Re: np435 is in
Post #7 by chad » Sat May 19, 2012 8:34 am
it's a 5 yr old thread 66poney. he may not B around anymore. Go to classicbroncos.com and scroll thru the stickies till U C an NP install thread. It'll have pic'n everything....
Good luck, hit me back here or on my email included in my signature below....
if U have HEF I guess U have V8? may need tailshaft housing from a 6 as adapter? They'll know.
I C this site for it's 6 cly expertise....
66WarPony
Re: np435 is in
Post #8 by 66WarPony » Sat May 19, 2012 3:55 pm
chad wrote:it's a 5 yr old thread 66poney. he may not B around anymore. Go to classicbroncos.com and scroll thru the stickies till U C an NP install thread. It'll have pic'n everything....
Actually, I have the 6 adapter... maybe I'm not looking in the right places but I was under ths impression that only the 6's came with the HEF. I also didn't bother to notice that the thread was so old, so thanks for the heads up. I'll check out CB and see what they say... Thanks!
chad
Re: np435 is in
Post #9 by chad » Sun May 20, 2012 9:18 am
yeah, is the hef a '66-only tranny? most 6 cyl have ran/rat? i 4 get them all...I just call it "3.03".
Explorer
Re: np435 is in
Post #10 by Explorer » Sat May 26, 2012 9:21 am
If you want something sweet, put a "GearBanger" shifter on that NP435. Put one on my last project. Makes a world of difference in shifting.
66 Bronco half cab, 203 ci, 9.7:1 comp, CI aluminum head and intake, DSII ignition, Clifford header, Keith Black pistons, Isky 256/256 cam, lifters, chrome moly rings, push rods, Holley 390cfm 4v, 4:11 gears, 3-speed, 30/9.50/15's 18.28mpg pushing a 4000lb brick.
66 Mustang Coupe, 200I6 automatic
80broncoman
Re: np435 is in
Post #11 by 80broncoman » Sat May 26, 2012 10:32 am
Explorer wrote:If you want something sweet, put a "GearBanger" shifter on that NP435. Put one on my last project. Makes a world of difference in shifting.
I am curious, Just what is this "GearBanger" shifter??
OAPSE Union Member
Real men don't wear Bowties
Explorer
Re: np435 is in
Post #12 by Explorer » Sat May 26, 2012 10:42 am
Re: np435 is in
Post #13 by bubba22349 » Sat May 26, 2012 5:12 pm
That's a nice setup :thumbup:
66WarPony
Re: np435 is in
Post #14 by 66WarPony » Fri Jun 01, 2012 4:43 pm
Damn, that is a SWEET setup! It seems pretty simple in design, I would imagine that you could fabricate it if you had some decent welding skills...
