Dropping a 250 into a Bronco
jimmyv65
Post #1 by jimmyv65 » Fri May 03, 2013 5:04 pm
Hi Guys,
I am slowly working on a Bronco rebuild. It is a 66 and was originally a 170/6. As part of the rebuild, I wanted to bump up size and stay with a six. In short, I bought a 79 Granada 250. I've been dealing with some of the mods it takes to get this into the truck. I haven't seen a complete list, so I thought I'd start what I've done so far and add to it.
1) Bell Housing/Clutch: You have to move up to the Big Bell and clutch for a 289/302. It all bolts up pretty easy. I reused the original 3 speed trans as it was in good shape.
***Update: The shift linkage from my 3 on the tree linkage needed to be adjusted(bent & cussed at) to properly shift and clear the larger bell housing.
2) Body Lift: I did a 2 inch. I don't have it together enough to say for certain, but everyone says you need the extra room under the hood. It does look like it will be close. I'll measure when I get the hood and fenders back on. I've read some folks getting by with a 1 inch BL.
3) Clutch Linkage: I had to do some cutting and welding as the original linkage is sized for the smaller bell housing. This mod has taken a bit, but was straight forward. I had to cut the pivot tube shorter and re-weld it. I had to adjust the mount for the pivot tube on the engine side. Again, the welder was my friend in making an extra support for the pivot tube mount.
4) Head/Carb Mod: Not required, but I had a machine shop machine down the log and I used the plate that allows a larger Weber to be mounted. I am going with a Weber 38/38.
5) Radiator: I haven't dug in, but it looks like I may need to do something a little different with my radiator. I was going to re-use the Bronco 170 one. I live in Wisconsin, so I figured I would be OK with the smaller radiator. I may look to get a Granada Radiator and mount it up.
**Update: I went with a custom larger aluminum radiator. I couldn't get that motor to cool enough on the Bronco 170 radiator. I had to neck down the output hose from the H20 pump to the bottom of the radiator. Dropped it from a 2.5" to a 2". I bought the Bronco lower hose and the Granada lower hoses, cut them in half & welded up a 2.5"-->2" reduction pipe to connect the two.
6) Motor Mounts: I just bought new ones from Classic Inline. I didn't have to modify.
7) Disty: Not required, but need to decided DSII from the Granada(maybe with an MSD) or DUI. I went with a DUI. It is a very nice unit.
8) Oil Pan: A few options: A) Just run the 250 pan and allow the potential clearance issue to exist. OK for more of a road truck or enough lift. B) Cut and weld the bottom of a 170/200 pan for a bronco onto top/mounting side of the pan. You have to extensively modify the oil pick up. C) Measure, measure and measure--cut the pan at an angle where it would not interfere with the pumpkin and weld on a patch plate. The oil pick up needs to be modified, but it can be done just by bending it.
I did Option "C".
I will add more as I get there.
1966 Bronco-'78 250-Meagsquirted TBI, DUI, Header, Cam, Hydroboost & Front Disc, Uncut, 1" body lift, 2.0" suspension lift
bmbm40
Re: Dropping a 250 into a Bronco
Post #2 by bmbm40 » Fri May 03, 2013 7:38 pm
Welcome to the club!
Hey I really like your mod for the oil pan, can you post pics? My Bronco is driven in northern Nevada and the original 170 radiator has been working fine. Would like to hear driving impressions. What is the axle ratio and tire size?
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
jimmyv65
Oil Pan
Post #3 by jimmyv65 » Sat May 04, 2013 7:47 am
Here's 2 shots of my oil pan during my my mock up. My method may not be as ideal as the full pan swap, but it looks like I got rid of the risks of the pan hitting the pumpkin.
Here's a shot of the finished product.
jimmyv65
Post #4 by jimmyv65 » Sun May 05, 2013 8:47 am
bmbm40 wrote:Driving Impressions...What is the axle ratio and tire size?
It has the 4.11's that came with it originally. The tires are 31X10.5's
It may be a couple of months before I can give driving impressions. I am closing down on a the end of a full rebuild project. It hasn't driven in about 18 months.
jimmyv65
Clutch Mod
Post #5 by jimmyv65 » Sun May 19, 2013 6:00 pm
The mount I had for the clutch mechanism wouldn't fit on the new set up. The pivot mount wouldn't line up and the equalizer bar was too wide.
I decided to shorten the equalizer bar by cutting it in half and re-welding with about an inch take out. The engine side pivot mount didn't line up on both holes(one on the engine, one on the bell housing). I cut off the back half due to clearance issues and welded up the bar that gave me a 2nd mounting point on the motor for the pivot bar.
Shortened Pivot Mount:
Remote mount point and shortened equalizer bar:
MPGmustang
FSP Moderator
Post #6 by MPGmustang » Wed Jun 12, 2013 10:03 pm
your work is great, I love it... but I see a problem... I hope you'll remedy soon :D
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
jimmyv65
Post #7 by jimmyv65 » Thu Jun 13, 2013 7:41 am
MPGmustang wrote:your work is great, I love it... but I see a problem... I hope you'll remedy soon :D
LOL! Brakes and Steer are over rated! I have the brakes done. It was a bit of work getting all that to line up nice with an angle bracket and a hydroboost unit.
I didn't intend for everything on this build to be a modification, but they keep turning up!
MPGmustang
FSP Moderator
Post #8 by MPGmustang » Thu Jun 13, 2013 4:56 pm
I figured your problem is the lack of dirt/mud on this bronco... :lol:
bmbm40
Post #9 by bmbm40 » Fri Oct 11, 2013 10:55 am
How's it going with your Bronco? Looking at the pictures again you did some nice work. Once again that oil pan mod you came up with is only way to go. Waiting to hear how it drives.
jimmyv65
Post #10 by jimmyv65 » Fri Oct 11, 2013 12:19 pm
bmbm40 wrote:How's it going with your Bronco? Looking at the pictures again you did some nice work. Once again that oil pan mod you came up with is only way to go. Waiting to hear how it drives.
I've been slowly plodding away at it. With my schedule, I really only get about 1 day a week with it. It is moving ahead. I am hoping to be done by Christmas...this year. :lol:
I'll get some further pics of the 250 related stuff going on soon.
Here's a pic of us getting ready to take it over to my buddy's paint booth. Time to finally get it all the same color.
jimmyv65
Post #11 by jimmyv65 » Mon Oct 21, 2013 10:49 pm
Now all one color
jimmyv65
Post #12 by jimmyv65 » Mon Oct 21, 2013 10:51 pm
Some engine bay pics:
bmbm40
Post #13 by bmbm40 » Mon Nov 04, 2013 10:36 am
Was checking out your build pics again. Looks like a frame off did you have a body rotisserie for that? Really looks good.
What headers are you using? Are those the stock acc brackets for alt, power steering etc? Did the 250 just drop in and bolt to the existing trans without having to move anything around- trans cross member or anything like that?
jimmyv65
Post #14 by jimmyv65 » Mon Nov 04, 2013 3:23 pm
bmbm40 wrote:Was checking out your build pics again. Looks like a frame off did you have a body rotisserie for that? Really looks good.
Looks like a frame off did you have a body rotisserie for that? I just built some wooden "saw horses" and welded up some door braces. It got the job done. You can see some pics of it if you go to this link:
https://docs.google.com/presentation/d/10-wqVwAO3O3QM1C6m8t_v2Tspm7UqIlT7ai1d2aSltQ/edit?usp=sharing
What headers are you using? That is the classic inlines header. It is a nicely built piece, but leave a tight bit of work to get the pipes around the starter and the frame. I am going to have a buddy who is an exhaust master weld it up for me. It goes beyond my basic welding skills.
Are those the stock acc brackets for alt, power steering etc? That is the stock brackets that came with my 250. I thought it looked cool having it all on one side. Some down sides to that though: 1) The wiring harness expected the alternator on the passenger side. It made my radiator hose set up a little challenging. I had to fit a custom neck down piece in behind that bracket. The Bronco radiator is a 2 inch set up and the 250 is a 2.5 inch. I don't think all 250 bracketry is like this. I think the early mustang and maverick set ups are a normal configuration with alternator on the passenger side.
Did the 250 just drop in? Yep. That part was really nice and easy. The 200 and 250 engine blocks are the same length. So transfer and tranny fitment was spot on. The motor looks a little longer due to the bigger and longer water pump on the 250.
Hope that helps. I can wait to get this puppy back on the road! It all still moves slow. If only I didn't have a job, a wife, kids, 2 small businesses, a dog, etc.....then I could work on my 66 full time. :lol:
-James
bmbm40
Post #15 by bmbm40 » Tue Nov 05, 2013 9:38 am
Frame off is the way to go.
I have a mini starter on mine that might help with header clearance but that is a little way down the road for me.
I actually have a set of acc brackets like yours that I bought somewhere but my 1970 250 has the traditional acc design.
A few guys on classicbroncos.com have asked questions about the 250 upgrade so I can tell them it is pretty much a bolt in. That direct mount conversion looks like a good job. Keep us posted.
jimmyv65
Post #16 by jimmyv65 » Mon Dec 30, 2013 10:02 pm
It has a face!
bmbm40
Post #17 by bmbm40 » Tue Dec 31, 2013 10:34 am
Good progress on your Bronco. Show car quality really you must be happy with the results.
Invectivus
Post #18 by Invectivus » Thu Jan 02, 2014 1:03 am
That's a good looking mug, good work.
1967 mustang coupe - 200ci, 69 dizzy, adjustable rockers, headers and dual exhaust, T5.
1964 convertible falcon - Gutted.
1973 EB Bronco - 302ci (sorry!) DUI ignition, C4/D20, Dana 44, 33's
jimmyv65
Post #19 by jimmyv65 » Sat Mar 08, 2014 6:42 pm
I want to mention something based on issues I had and some private message questions people have sent me.
Regarding flywheel & bell housing choice...know what you are grabbing. In simplest terms, there seems to be essentially two sizings(vast generalization as there is a little more detail beyond that). Some call it the big block bell housing vs. small block bell housing. That isn't a great description as you can find the two different sizes on small blocks.
Key questions to ask yourself:
Are you going to do 157T or 164T on the flywheel?
Is your bell housing designed for 157T or 164T?
What clutch fork and clutch linkage will you use?
Mechanical vs. Hydro? The Bronco is a mechanical clutch, so a hydro would be some extra fab and customer work
Do you have the right starter set up for what you've selected?
157T and the associated bell housings are found in the V8 Mustangs and other car applications.
164T and the associated bell housings are found in truck applications and some bigger engines in cars.
Keep in mind with the 250, you need a zero balance flywheel.
157T Zero balance flywheels--I could only find these via Ford racing. Maybe there are others places, but I didn't find a vehicle application for it.
164T Zero Balance Flywheels are used behind the 300 straight sizes in the F150's(also the 240 sold in the 70's). These flywheels are cheap and easy to buy at NAPA and other auto parts stores.
People have asked me--which one should I get? It depends! I'd say I think the simplest is the 164T set up from a V8 and keeping the mechanical clutch and linkage.
I hope this helps and if others have more info, let me know and I can update.
Here's a couple pages that helps:
http://www.bcbroncos.com/ford%20starters.pdf
http://www.mustangtek.com/Bellhousings/Bellhousings.html
bmbm40
Post #20 by bmbm40 » Thu Mar 13, 2014 12:40 pm
More good information to have and should be very helpful for those thinking about the 250 for their Bronco. I stumbled across a 250 fw on ebay when I installed mine, did a search for ford 250 fly wheel I believe. The advantage with the 300 setup is larger clutch and easier to find. Often wondered if I should have gone that route.
Broncitis
Post #21 by Broncitis » Tue Mar 18, 2014 9:54 pm
Really nice job on the bronco. Like I always say, really like the people who do instead of talk. Been working on mine for 21 years.
69 Early bronco, 4.11, toploader 4speed, 68k 3inch body lift, ET about 50 something!!!
jimmyv65
Post #22 by jimmyv65 » Tue Mar 18, 2014 10:06 pm
Broncitis wrote:Really nice job on the bronco. Like I always say, really like the people who do instead of talk. Been working on mine for 21 years.
Thanks! I am still having fun on the project and I am enjoying how it is turning out. I am doing the final steps to test fire the motor. I've got a short list after that to declare it done. Soon........OK, by summer.
jimmyv65
Post #23 by jimmyv65 » Sun Mar 30, 2014 6:06 pm
Big Milestone this weekend. Fired it up for the first time! Wow, is that puppy loud through an open header.
The list is getting shorter. It should be a driver soon.
garyt120r
Post #24 by garyt120r » Sun Mar 30, 2014 9:51 pm
That header looks really good. Do you think that you will have issues with fram clearance? If not I'll pull the trigger and buy one myself.
jimmyv65
Post #25 by jimmyv65 » Mon Mar 31, 2014 8:55 am
garyt120r wrote:That header looks really good. Do you think that you will have issues with fram clearance? If not I'll pull the trigger and buy one myself.
Frame/Body Clearance for the header is a challenge. I will be able to tell you more after I get the exhaust fab'd. We already adjusted the direction of one of the header collectors to give us a better angle. It will be a tight fit.
bmbm40
Post #26 by bmbm40 » Mon Mar 31, 2014 10:04 am
Congratulations!
Is that a stock rebuild on your 250, don't remember seeing mention of a cam. Also what color is that on the block?
Thanks
Post #27 by bubba22349 » Mon Mar 31, 2014 11:52 am
:beer: Congrats that's one beautifully detailed Bronco! :nod:
jimmyv65
Post #28 by jimmyv65 » Mon Mar 31, 2014 1:08 pm
bmbm40 wrote:Congratulations!
Thanks
Yeah, I guess I didn't speak much on the rebuild. It has a mild cam (264/264 I think). The compression was bumped up as well. I am hoping those changes along with the Weber 38/38 and header/exhaust make it a fun drive.
Nothing special to that color. It was a generic dark silver in engine paints available at my local auto store. Many of my accent colors are dark grey/silver, so it seem to fit. I don't think it is a Ford color, but neither is the exterior paint.
jimmyv65
Post #29 by jimmyv65 » Mon Mar 31, 2014 1:10 pm
bubba22349 wrote::beer: Congrats that's one beautifully detailed Bronco! :nod:
Thanks! It is funny how far I've moved off the original idea. At the start of this project, it wasn't going to be a purty truck. I just wanted a strong usable runner. I've moved way off that goal. I will like the outcome, but I let the scope creep away on me. Good thing the wife has been supportive.
jimmyv65
Post #30 by jimmyv65 » Sun Apr 27, 2014 10:30 pm
Getting close to the final under hood configuration. The custom intake needs to be polished or finished in some way. I've got a few other things to address as well.
bmbm40
Post #31 by bmbm40 » Mon Apr 28, 2014 10:38 am
Very well done. That is going to be a blast to drive and will get lots of attention. Looking forward to hearing feedback on how it goes with that built 250 it should have a bunch of low end torque.
jimmyv65
Post #32 by jimmyv65 » Mon Apr 28, 2014 10:43 am
bmbm40 wrote:Very well done. That is going to be a blast to drive and will get lots of attention. Looking forward to hearing feedback on how it goes with that built 250 it should have a bunch of low end torque.
I am excited too. I hope to be test driving later this week or this weekend. As we are tuning and shaking out in runs in the shop, the motor feels strong. I think the header into two longer pipes into one will help draw out some of the torque.
I'll get more pics of the exhaust as we get it out of the garage.
jimmyv65
Post #33 by jimmyv65 » Sat Aug 16, 2014 5:29 pm
Well, It has been together for a while and I've been driving. I am really happy with the motor set up. Lots of torque!
Weber carb tuning is a dark art. I've got it pretty good, but need to do a little more tuning.
bmbm40
Post #34 by bmbm40 » Sat Aug 16, 2014 7:08 pm
It looks great!
Broncitis
Post #35 by Broncitis » Sat Sep 27, 2014 2:43 am
That is one well done bad azz bronco, absolutely beautiful, hope to paint mine in a couple years after I'm finished.
Prizefighter300
Post #36 by Prizefighter300 » Wed Sep 16, 2015 5:35 pm
Do you have any videos of it running? How do you like the gearing paired with the tire size?
1970 Ford Bronco EFI 300 Project
A few other Broncos
jimmyv65
Post #37 by jimmyv65 » Thu Sep 17, 2015 7:44 am
Prizefighter300 wrote:Do you have any videos of it running? How do you like the gearing paired with the tire size?
Tires size and gearing worked out great. I had used one of those tire size and gearing RPM calculators before I bought them. I have very nice acceleration and on the highway, the RPMs aren't bad.
chad
Post #38 by chad » Thu Oct 29, 2015 9:12 pm
may B a custom curve on the dizzy?
jimmyv65
Post #39 by jimmyv65 » Mon Nov 09, 2015 7:49 am
Just shot a shot tail pipe video with the new cam.
https://www.youtube.com/watch?v=AeX4QVqkx4Q
bmbm40
Post #40 by bmbm40 » Mon Nov 09, 2015 7:45 pm
Sounds good!
chad
Post #41 by chad » Mon Nov 09, 2015 8:21 pm
U Go James!
lopey popper!
chad
bronk 4.1L ('69 - '83) falcon motor, 240tq @ 1600 rpm, SBF
Post #42 by chad » Mon Nov 09, 2015 9:39 pm
What headers are you using? That is the classic inlines header. It is a nicely built piece, but...
Try the ‘stang ‘80s, ‘90s (v6) starter? I will. Smaller – like the expensive “minis”.
Mechanical vs. Hydro? The Bronco is a mechanical clutch, so a hydro would be some extra fab and customer work.
I will use the NV3550 so the Q is answered w/in itself.
ZF would B nice/easy by placing a Ranger hydro clutch (slave'n it's line) in the bell.
Got a '77 C4 from a bronk prts vehicle. May use it if daughter wants the rig (she's 19 y/o now…never drove a stick).
Post #43 by bubba22349 » Tue Nov 10, 2015 12:11 am
:beer: sounds decent :thumbup: :nod:
jimmyv65
Re: bronk 4.1L ('69 - '83) falcon motor, 240tq @ 1600 rpm,
Post #44 by jimmyv65 » Tue Nov 10, 2015 7:20 am
chad wrote:What headers are you using? That is the classic inlines header. It is a nicely built piece, but...
Thanks! Good Info to know.
jimmyv65
Post #45 by jimmyv65 » Tue Nov 10, 2015 7:21 am
bubba22349 wrote::beer: sounds decent :thumbup: :nod:
It does! Kinda surprised me a bit. It is the Clay Smith 274/274 Cam. So far, I am really liking it.
edgewood bronco
Post #46 by edgewood bronco » Tue Nov 10, 2015 8:53 pm
That's sweet! I'm enjoying mine, which has a 200 with the same head mods as you did, although I opted for a 2100 Autolite carburetor. I like your air cleaner setup, gotta do something like that for mine.
That setup along with 4.11 gears and stock 15 inch rims (that's about what, 26 inch tires?) got me 16 mpg today. Pretty pleased with that. This weekend's its first camping trip.
62 F100 223
66 Bronco 200; autolite 2100 2 bbl conversion: Lovin' it!
chad
Post #47 by chad » Wed Nov 11, 2015 2:28 pm
jimmyv65 wrote:
chad wrote:[b]Thanks! Good Info to know.
I see a 'fancy' Saginaw PS pump (and 2 belts throughout) which has dual duty (hydrobost breaks/steering) I assume.
What part number or yr/make/model did you source the PS pump (and the MC hydroboost from)?
Some use the Astrovan's hydroboost MC...
1966Mustang
Administrator
Post #48 by 1966Mustang » Fri Nov 13, 2015 1:24 am
Hey Jimmyv65 - Nice bronco!
We're trying to get a youtube channel going at : https://www.youtube.com/channel/UC-kb13 ... NA300XQmqw
It's not really 'Official' yet, as I have no idea how to manage a youtube channel or the subscribers to it, but I'm learning.
Could we steal your video to post it up there? C'mon first video!!! Whaddaya say?! :D
Thanks,
Perry
'65 Mustang Coupe, C4, DUI, CompCams 260, Addco 1", StreetOrTrack Front Bilstein Coilover System, Bilstein Rear Shocks, 4-1/2 leaf springs.
Support our forum:
Like us on Facebook, watch us on YouTube, Buy FordSix Gear , Make a Donation!
jimmyv65
Post #49 by jimmyv65 » Fri Nov 13, 2015 7:49 am
1966Mustang wrote:Hey Jimmyv65 - Nice bronco!
Thanks,
Perry
Sure!
jimmyv65
Post #50 by jimmyv65 » Fri Nov 13, 2015 7:52 am
Yep, that is an Astrovan booster. No big logic to that one. They seem to be the most used one for custom systems. I think you could use any model you could find. I found the Astrovan one cheap.
The pump and double belt is the stock set up that came with my motor. I don't think it really needs a double belt.
The hydro boost works very well. I am not tied to motor vacuum, which is great. Especially with this lumpy cam.
