2018 Contributors:
250 CI Swap into 1970 Bronco
70Bronco250
New Member
Post #1 by 70Bronco250 » Wed Sep 18, 2013 10:17 pm
I doubt this is the first time someone has brought up the swapping of a Ford 250 six cylinder in a 1970 Bronco. So forgive me for bringing up a topic that likely has taken up much discussion time in the past. I would simply like to have a short totorial on a successful swap. Anything that removes easily avoided mistakes would be great. I understand that the 250 is roughly 2 inches taller than the 170 or the 200 and does that require a body lift for hood clearance issues or a hood scoop of some kind? I amconsidering a transmission swap also to get better economy and again a little more fun factor . Recommendations on transmission swaps would be welcome also.
This is a father son project and I am not looking for rocketship performance but rock solid reliability and fun factor for my son and myself. He wants to learn to drive a stick and I can not think of a more fun stick to learn to drive than an early Bronco.
Thank you ahead of time.
Doug
bmbm40
Re: 250 CI Swap into 1970 Bronco
Post #2 by bmbm40 » Thu Sep 19, 2013 9:17 am
Do a 1" body lift. Your rubber body bushings are most likely in need of replacement anyway. I slotted my motor mounts to drop the 250 lower but doubt if it was really needed. I have no hood clearance issues with the stock air cleaner.
I went with the NV3550 which is the best choice in my opinion but if i did it again I would use the M50D as it would probably cost a lot less. The torque characteristics of the 250 are well suited to the bronco along with a trans upgrade it is a great driving experience.
Start gathering parts soon. Let me know if I can help. Also classicbroncos.com has lots of good info.
bmbm40
Post #3 by bmbm40 » Fri Sep 20, 2013 5:15 pm
Also you may want to move this to the Bronco section. Not sure how to do that.
I don't think there are any real pitfalls to this conversion. Mine was done about three years ago but I remember having to fab up some clutch linkage. Also you will need a 300 flywheel and bell which you might get with a junkyard M50D which was used on F 150's. Somewhere on Classic inlines site there is a discussion on 250 swap stuff just have to look around. The oil pan needs a little work and someone on this site or classicbroncos.com came up with a good solution, when I find the link I will send it to you. Good luck.
bmbm40
Post #4 by bmbm40 » Wed Sep 25, 2013 1:26 pm
It's all coming back to me now.
You might find a 250 flywheel somewhere I happened across one on Ebay but a member on here might have one. Also any sbf bell should work and I seem to remember if you use a 300 bell and flywheel you can use a larger clutch.
If i remember any thing important I will let you know.
bmbm40
Post #5 by bmbm40 » Fri Oct 11, 2013 10:57 am
See the work jimmyv did on his oil pan. That is the way to go.
Users browsing this forum: Baidu [Spider] and 3 guests
